2016 Z71 with Front Air Dam Removed?
Quick question for the 16 folks here because I forgot to look, do the 16's come with the wheel well liners? I know I added them on my 08 and found them to beneficial, but I forgot to look on a lot and see if the 16's have them standard.
Yes. Mine has the liners
  • Replies 70
^Beautiful country and truck. I love that blue. Thanks for the answer guys. I thought I saw them when I was looking, but the last week or so has been crazy. A new baby daughter will do that I suppose, ha.
Can you remove what's left of the gray plastic or no?
You could but it won't look right.
-tapa
Mine did.
Broke her dirt/4wd cherry today. Definitely need new shocks. These ranchos are complete sht. We were bouncing around like popcorn. Has a great 4wd system on it though. No traction issues at all on these terrible tires.
b9gJAoHh.jpgYE1jO6Yh.jpgxkCYwZ2h.jpg0nofjXoh.jpg2gRL3cgh.jpgpcvA72ph.jpgCZXri8xh.jpgXXA6N1ah.jpgJM7SKDDh.jpgXWSMjT9h.jpgJL6nMaEh.jpg
Where do you go to see that off road gauge cluster? I have a 2016 Sierra but haven't had it in 4wd yet. Will it automatically display?
Mine did.
Nice pics, sweet truck.
I think you have to tell it to come up. It's under the "info" menu after enabling it in the "info" settings. There's about half a dozen options that don't show under info by default.
Thanks dude.
-tapa
I really do wish you could remove the rest of the gray plastic up front so it's even with the rest of the truck but until then this how mine looks.
I think it looks good. you could vinyl wrap the chrome
Yeah I think the tails are LED too. I don't think there's an incandescent in the whole truck.
I have the same truck as yours but with the 5.3 and I have 20s. There is 7 incandescent bulbs on out trucks that I have found so far. The license plate lights 2,backup lights 2,the cargo lights on top of the cab 2, and the center high mounted 3rd brake light 1.
Nice investigatory work.
-tapa
-tapa
I'm in the process of changing them all to LED. 194 for the license plate and 921 for the other 5. But one of them should be tinted red for the 3rd brake light otherwise it looks goofy.
Very Nice. I have an 2016 2WD LTZ Ocean Blue Metallic on order.
Like Tom Petty said "The waiting is the hardest part" :)
-tapa
good looking truck . change those blubs to led's
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
