2016 Z71 with Front Air Dam Removed?
I love the all LED lights. Didn't want some of the options that came with the LTZ package though (namely leather). If anyone ever figures out how to get rid of that hyper flash without wiring in resistors, I'll switch out all my bulbs to LEDs.
I am going to go get rid of that lower air dam right now though. I think it'll level out the bottom of my truck nicely with my steps.
I thought about that or plasti dipping it but I'm still undecided.
The WT has a solid black air dam. Might be able to find someone to trade with, or order from GM. I hate chrome and have been looking at options to get rid of it.
  • Replies 70
Looks better now, I like how it matches up nicely with my N-fabs.
f86b96eb-a0fe-4f0f-a2d0-f6e0e0b96450_zps
before
Looks good. I'm glad I took mine off as well, it just doesn't look right. I can't imagine there being much down side to removing the dumb thing.
Very Nice. I have an 2016 2WD LTZ Ocean Blue Metallic on order.
Like Tom Petty said "The waiting is the hardest part" :)
Has your truck came in yet ?
I'm waiting on a loaded out Regular Cab in the Ocean Blue Metallic too !
before
Looks good.
Not yet. It wasn't suppose to hit the assembly line until next week. But my dealer said that it was built and being shipped.
No delivery date yet. But I am a week ahead of what I thought the schedule would be.
Sounds like we are pretty much in the same boat.
My was suppose to be built this past week and wasn't as of Thursday......so maybe it was built Friday.....hopefully :)
Hope they both get here quick !
Even with the air dam completely off on my 2014 it is still too "dam" low. Had it parked next to my F150 work truck this weekend and it has 3 inches more ground clearance up front with the air dam on compared to my truck with the air dam off.
The GM's have always sat lower stock than Ford or Dodge. I've always wondered why.
I wonder if any company out there is interested in making an insert to make it look more finished if you were to remove the upper air dam... Or anyone with a 3D printer? I'd buy one in a heartbeat.
Sry to go off topic. But what are getting mpg highway. Love your setup
Thank you!! If I'm really trying I can get around 18. The wheels and tires really killed my MPG but it was totally worth it to me.
  • 3 weeks later...
Does anybody know the part ## to the air damn w/chrome? Greatly appreciated.
Go to a web site that sells GM parts and do a search, not that hard to do.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
