What is a good all terrain towing tire?
99-ls1-ss
There are tons of posts about tire sizes but I didn't see one related to towing and being all terrain. If I missed it I apologize.
I've towed my boat more times than I can count but it only weighs around 4500 lbs. I will now be towing something heavier and I want to make sure I have the right tires for the job.
What are things to look for in a tire when towing 10,000 lbs (3500 lbs trailer and 6500 lbs tractor) mostly on pavement and occasionally off-road but, not rough? I will be driving through a field to get to the tractor.
Edit - This will be a bumper pulled trailer. The truck pulling it is a 2016 Sierra SLT with the 6.2L Max Trailering package.
Very dependent on the trailer setup. Is this thing a bumper hitch or gooseneck. Tire loading can vary greatly.
It will be a bumper pull setup. I added this information to my original post.
I wouldn't worry about the tires at all then. 10k will pull the bumper off. Problem solved.
So GM is full of crap with their tow rating of 11,700 lbs?
No GM is not full of crap. I am assuming when you say bumper pull you are generally referring to a tag along trailer as opposed to a gooseneck/5th wheel set up. Im guessing Bdbake1 either is not familiar with the common usage of the term bumper pull or is having fun.
In either case in guessing (without knowing more specifics) your truck should handle that well enough for occasional trips. I occasionally use my 2014 CC 5.3 3.42 to tow a 20', 3k bumper pull with roughly 6k on it and it does well for the occasional trip.
If I had the need for more regular use as well as the money I would trade up to a 2500. That being said, with the weight you are talking about you technically should be investing in a weight distributing hitch as well as LT tires. I ended up getting a set of air bags instead. This has helped immensely with sag and handling characteristics when towing heavy. However, as I mentioned the proper way would be a WD hitch.
As for tires, a couple of months ago I would have recommended Hankook Dynapro ATM, but they have recently started showing signs of premature cupping and noise despite having good alignment. The LT tires are worth the investment but I cannot recommend the Dynapros for the above reason. Good luck and be safe!
Load range E LT rated tires in whatever tread pattern you like the most
I bought a second set of OEM wheels in 18" for towing/snow/offroad use. I also bought 275 65 18 KO2s in E load range. I considered Michelin LTX I think in a E load range but all the glowing reviews of the KO2s swayed my decision. You can feel the weight difference but it's not bad and I lost about 2 mpgs. I haven't felt like reinstalling the wheels/tires that came with the truck so they're just sitting in my garage. BTW, I have a '15 SLT 4x4, 6.2 Max tow.
Just having fun, though probably a bit more mean spirited than what was called for. I do apologize. As for "bumper pull", that's a ball on a bumper. Barely capable of pulling a few bicycles. I'm well aware that the term is commonly thrown around to describe a proper Class III-> receiver hitch as well which, of course, doesn't involve the bumper in any way, shape, form or fashion. So how that setup became known as a "bumper" pull is beyond me.
To the OP, the non-smart asses in the room have given excellent advice. LT tires with a load range that's in line with however much load you intend to place on them. For the kind of weight you speak of, you'll want a proper WD hitch. Figure out how much of the weight you intend to place on each axle, and choose a load range that's appropriate. E will certainly do it, may be overkill for occasional use. It's haaaard to beat a Michelin LTX.
?Figured that was something along the lines of what you were going for ? For whatever reason in a couple of the forums folks commonly refer to tag along trailers as bumper pulls... I dunno either where the that became a colloquialism for non-gooseneck/5th wheels. I still see a lot of trucks in my area with serious damage to the bumper from trying to tow without a hitch. And yes, I definitely agree the WDH is the proper way to go!
I'm curious why you bought the 18" wheels for towing. GM forces the 20" wheels on the max tow package and I'm guessing its for the stiffer sidewalls which should help with trailer sway.
I've been thinking about 18" wheels so I can run decent snow chains, but was wondering what I would give up in towing capacity.
I also the same setup: 15 SLT 4x4, 6.2 Max tow.
I went with the 18s for a number of reasons. I like the look, better tire selection, going with E rated tires I thought better ride quality but still stiff enough for towing, I was keeping the same basic circumference so I thought the extra sidewall would be better off-road and I thought better if I needed snow chains. The 5.3 Max tow tow rating isn't much less than a 6.2 so with proper D or E rated tires I don't think your tow rating would suffer. I'll still be well below the tow rating and I'll be running an Equalizer so I'm not worried.
Good advise getting LT in E range. My son has a 2011 6.2 NHT he has the Michelin LTX AT2 in E size. There pretty tough and he has pulled a tractor on our car hauler many times (with air bags) with no problem. Nice looking truck you have there man that 6.2 is a beast in a 1/2 ton truck I love driving it I can put that thing in M5 and she will flat pull your gear. Good choice :thumbs:
A WDH is in the works right now. I have a Weigh-Safe hitch to get the tongue weight right. The WDH is next and then tires. I just want to start looking for the right tire for the job so I can tow safely.
So, a D or E rated tire should be ok for what I'm hauling?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
