Looking to see where everyone is mounting their aux switches for light bars on the 2014+ GMC's. I have the trailer package so the trailer brake is in the way on the left side.
I have a couple cubes and a bar I want to put behind my grill but would like to have an idea of where the switch can go.
Anyone mount a switch in their center console?
This is what I did.
There is lots of 12V outlets so I didn't mind losing one. Still looks factory when cover is down. No modification of the hole at all. If I wanted to remove the switch and put back the 12V outlet back, I could.
Here's how I did it. No drilling. Switch tightens right up to the rubber and does not move. That rubber slip is pretty stiff so it doesn't even move when I push on the switch.
Equis24x,
I have the same truck as you and thought of that but was unsure. Could you please clarify how you did that and where parts were sourced ?
Nice job, btw !!!
Dave
See this thread
I second that. I'm in the process of getting mine going. It will give me 4 switches and still have the factory look without drilling or losing anything. May cost a little more but it's worth it to me. I guess it only works though if you don't already have a full switch bank.
This is what I did.
Where did you buy your switch?
I got mine from Canadian Tire...however, all auto parts stores carry them. It's just a standard round led toggle. You can get them from ebay, amazon, or practically anywhere. Just search round led toggle.
This is what I did.
I did the same thing.. don't have any use for 3 12v ports, so I removed one.. no damage/ modification whatsoever and I can put it right back to factory in about 15 minutes.
http://imgur.com/NdeGLBn
http://imgur.com/meHj32Q
Both look great! How hard was it to locate your switch there? And how did you remove the power outlet, what's the process of getting that bad boy out of there without breaking anything?
Edited by bwilloby46
here is what I did. Not exactly pretty, but unless you look up close it looks fine. I broke off/took out the left side stationary part. Then i cut the circuit board behind it so I could fit the switch. Then I just took some plastic sheet I had laying around and trimmed it to fit in the hole, and painted it. It's real easy for me to hit it by feel.
s
Edited by thetruck454
Wasn't that bad.
First open your console lid. With it open, now you will have to pull up and back on the top grey plastic piece that goes around the entire console which is also connected to the cluster part that holds all the 12V and power supplies. Once you pull that off you will have access to the back of the plugs. You can pinch 2 prongs that remove the 12V outlets. Remove whichever one you want.
Remove the socket from the plastic housing and your switch will fit right in the plastic housing piece.
Clip back in and you are good to go.
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
