Range AFM Disabler Warranty Safe in 2016?
The range device does not alter the stock programming, it only intercepts the signal and changes the signal to keep the AFM from activating. the reason it causes issues is that it is messing with devices on the CANBUS system that the modules use to talk to each other on. The same issues come from using those Progressive modules in the same way.
It wont void your warranty at all since it is not changing the factory calibration, but if it causes issues you will have to remove it.
  • Replies 63
Plug the mother in and use it. Quit worrying. We've got data loggers plugged into every one of our fleet vehicles and GM has no problem with it
There's a difference between monitoring/collecting data from the bus and modifying data and sending it out on the bus. I doubt that GM can tell if you had one and removed it, but I sure wouldn't bring it in for service with the module attached.
Well CRAP .... you guys are making me think twice about plugging this thing in! :(
I will not in any way use a tuner like some have suggested ... if this device may be able to be seen somehow then a tune will No Doubt be seen (and I know you can revert to factory but those leave lots of trails I have been told).
Seems some have had issues with codes running this lately.
I have a 75K full 100% factory warranty .... paid extra for no limitations on my 3 year 36 month and added the extended full coverage up to 75K for just under $2K more .... Sooo, with that kind of money been spent on a warranty I do not want to screw it over by using something like this.
I know damn well my service dept. guy will say "No you can't use that it will void your warranty" .... So I have been trying to get more from others here who have used it.
I used it on my 2011 Sierra for 3 years straight without a single issue, no code, no nothing with an extended warranty. Not sure what may have changed since then.
I read above that some guy had OnStar tell her had something plugged in he shouldn't have ... that's my worry ... that could cause problems I think.
Well crap ... my Range device is due back in the mail to me today and I'm not sure I want to plug this thing in now. Hmmmmm
I say run it, the V 4 on these trucks are brutal. Best thing i have ever done to this truck is get this device. Honestly was thinking of selling the truck before i bought the Range. Put it in and the truck was again perfect for me.. as i am sure you know as you have had it in your old truck. run it until you warranty is done with then tune to shut it off. just my 0.2.
hey guys, sorry to do this to the thread.. but can anyone please explain to me how to start a new thread? its been driving me crazy as i have been on here for months and still cant find where to do this. thanks.
If it does throw errors and codes will those all be cleared once the device is removed?
Is there a process to make sure those codes are removed? Disconnect battery etc.?
Just preparing is all in case it does cause an issue and I need it to stop or be cleared.
Thanks guys for the replies
The point is there many things aftermarket to plug in and monitor. GM via ONstar doesn't know or care what it is. It's not probing it. Remove whatever you have connected when at the dealership. Really, people overthink this too much
Get a scantool that can erase codes
Any recommendations for a cheap scan tool to accomplish this?
I would think though just after removing it and maybe disconnecting the battery etc. the codes should clear if in fact it does throw any codes at all.
Yes I Knoooww I'm overthinking it but that's what I do :) .... I know everything about everything before I use it or install it on my truck ... hell I'm that way with anything I use or buy.
a basic scanner will not clear the codes. When my truck had the Service Stablitrak and Service Brake Assist warning messages, I took it to my Uncle's repair shop first and his scanner would not clear those codes. So I took it to my GMC dealer and played dumb and they cleared them.
On the right of this below linked screen it says "Start New Topic" It also says it at the bottom on the right. Must be logged in else it says "Please log in to post a topic" voila
http://www.gm-trucks.com/forums/forum/169-20142015-chevrolet-silverado-gmc-sierra-1500/
Jim
most scan tools cant clear codes in the stabilitrak or ABS brake system, they usually can only clear the driveline codes only.
Used the range on my Avalanches, no permanent changes in engine programming or calibration and no detectable footprint once removed. Just don't leave it plugged in when you take the vehicle to GM for service.
Somehow the V4/8 switching is less detectable on the Silverado's direct injection 5.3 as opposed to the older 5.3s in my Avalanches.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
