R-1234yf Refrigerant Rollout Coming in 2017 Model Year
My Jeep has it. AC seems to work fine though I know it's a lot more expensive. You can thank the EPA for it.
Purpose for this is?
Probably have to have a special permit and license to handle it.
wee
wee
You have to have a special permit and licence to handle r-134a already so why would it be any different? It's another licence but it's not going to be any harder to get I wouldn't think.
Although HFO-1234yf is classified slightly flammable by ASHRAE, several years of testing by SAE proved that the product could not be ignited under conditions normally experienced by a vehicle. In addition several independent authorities evaluated the safety of the product in vehicles and some of them concluded that it was as safe to use as R-134a. In the atmosphere, HFO-1234yf degrades to trifluoroacetic acid, which is a mildly phytotoxic strong organic acid with no known degradation mechanism in water. In case of fire it releases highly corrosive and toxic hydrogen fluoride and the highly toxic gas carbonyl fluoride.
Anyone can buy 134a.
wee
wee
Anyone can buy small amounts of 134-a
I buy it by the truckload of 100lb bottles. Gotta have a license for anything over 1 lb I believe. You also have to have a licence to perform repairs to any auto air conditioning system in a shop (read as "for hire")
Here's the epa website on the matter. It's kinda convoluted but what government text isnt.
https://www.epa.gov/mvac/servicing-motor-vehicle-air-conditioners
Anyone can install 134a without a license.
wee
wee
Correct. As long as they are not being compensated in any way and are not making repairs to they system.
That always gets me. I have to carry certification to perform a/c recovering/recharging, and if I don't or if I am found in violation, the epa can fine my shop and me thousands of dollars.
But any idiot that thinks because he can spell mechanic he are one can go dump his entire system into the atmosphere and go to aurozone and buy the stuff to recharge properly or improperly and skate through the cracks.
Yep. Cause the epa doesn't care if you fill a leaking system. But God forbid you fix a leak without their approval.
Makes cents dont it hehe.
wee
You will know it's leaking TFA has a terrible smell. And corrodes any metal it touches including stainless. We use that and TFA (anhydride) in a reaction and it tears up the stainless dipsticks we charge it with.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
