2wd lifting questions/regrets/advice?
Whats up fellas,
I have a 2015 silverado 5.3 V8 that im looking to get lifted with some 35s. Looking through the threads it seems most are 4wd vehicles so Im looking for some of the 2wd truck drivers advice.
Im in California so its not gonna be off pavement too much except for all the pot holes around L.A. and the occasional dirt road to fishing holes in the sierra mountains. Im coming from an 01 f-150 4wd with 8 in lift with 37s but i just did not use the truck to its capabilities enough so opted for a 2wd this time.
Any advice on lift kits or setups with levelers/body lifts? Im currently leaning toward a pro comp kit 6" to clear those 35s
Any regrets or changes you also wish you would have done?
4.5" Maxtrac spindles with Bilstien 5100's will get ya about 6.5", enough to clear 35's. Add a 4-5" block in the rear, pretty cheap setup that'll still ride nice.
I run 3" Maxtrac spindles with Fox 2.0 set at a little over 2" of lift, and run 295/60(34x12). Wish I'd have gotten the 4.5" spindles though. Probably gonna add Zone 1.5" body lift soon.
with just the spindle lift will the front tires stick out further than the back ones?
Typically yes. It's the only way to keep similar alignment geometry.
I added 1/4" wheel spacers in the rear of mine with the 3" spindles. I believe with the larger spindles, they'll stick out a little more.
  • 10 months later...
Did you like the quality of your kit? I am thinking about getting the 4.5 spindles with adding a .5" spacer totaling 5".
Yeah man, no problems. Maxtrac spindles are beefier than the stock ones.
I don't go jump sand dunes or anything, my truck is mostly on the street. Perfect lift for a pavement princess. Cheap and rides like stock (until ya put on new big heavy tires).
Post some pics when ya done!
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
