824 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Just had my 2015 sierra 6.2 8 speed at the dealer today there's a new bulletin that came out 1/20/17 16-NA-411 for hard shifts, clunks , v4 to v8 banging noise in trans so far so good we'll see.
Do you know what was done? Reprogramming? Something done physically to the trans?
I think that TSB is only for 15 and 16 model years. I wasn't able to find anything matching for 17 model years. That being said, I did notice that the loaner 2017 6.2 8 speed I had for a short time had a defined kick when downshifting to gear 1. My new 2017 5.3 8 speed is smooth like butter.....although I only have 900 miles on it, time will tell.
my 8 speed works good, only thing is if you stop real fast it will kick you in the butt when it shifts fron 2nd to first. i just learned how to keep it moving till it shifts all the way down.
I fixed this by driving 5 miles in m6 between 1100-1500 rpm
C1 relearn outlined here.
http://gm.oemdtc.com/492/transmission-adaptive-functions-and-correcting-low-mileage-harsh-shifts-2015-cadillac-chevrolet-gmc
-tapa
Edited by m3n00b
After an extended drive on Sunday and about 250 miles since getting the AT back from dealer all seems good. No more shudder felt between 62-72 miles per hour under light load. Will keep everyone updated.
Wife said today: if your transmission can't be fixed, at about 35k miles you need to trade this truck in...
I just bought a 2016 GMC Sierra SLE used with 2,800. My previous truck was a 1999 Chevy LS Z71. 4 transmissions at 280,000. I bought the new one thinking there is no way GM has not fixed that problem...My biggest complaint about the Sierra is electronics. The throttle response is horrible. Sometimes snappy other times it falls on its face. Seems to do exactly what you don't want it to do. Also, when going up a small incline if you're not careful the shift to 1st is horrific. Huge clunk shakes the whole truck. Most shops say it because of modern transmissions. Blaming computers on shifting timing. If you pull the fuse to the stabiltrack it helps. Frustrating, I know it's just a truck but my 99 would smoke my new one 7 out of 10 times. I tried a hyper tech programmer. Didn't change any of the unpredictable lag. Is there a clean way to remove all electronics with a switch on the dash? I know you can pull the fuse (or interrupt the circuit with a switch) to the stabiltrack but it flashes errors on the dash. I'm an electrician so I understand basic circuitry. Is it possible?
PS
If we are adding switches, what about a switch to lock the locker on the dash?
Will be taking mine in next week for the trans shudder. Mine does it at occasionally in any speed. They want to do a flush and something else first to see if that fixes it. If that doesn't fix it, then they will replace the torque converter. Luckily, I know the mechanic that will be doing the work, so I know exactly what will be done.
I have a 16 5.3 8 speed and have the same Trans issues. I had the Torque Converter replaced a few months ago and it did get better. I tow a 9k pound RV and am generally happy with the truck. What does piss me off is the Catch Can issue.... Someone else said it but after paying 53k for a new truck we should not have to do anything to it! If they know there is a Catch Can issue they should address it, AFM address it.... I am not rich but like most am a hard working man who has looked forward to having a truck like this and have no problem paying 6 hundred bucks a month for the privilege.... But GM should be embarrassed!
But hey, this is the new world we live in..... On a side note going in to get the Bow-Tie illumination option installed this morning.
Great Site here...
Kudo's
Keith
I have the 6.2 8spd in a 2016 and it shift like butter. You literally have to watch the tach in order to tell the shiftpoints above 2nd gear. In fact- this is the best motor/tranny combo I have ever owned, including one CVT in a Toyota.
CVT? Really? I can't even describe how much those things want to make me kill somebody! Maybe they are better now.....
CVT's and hybrids are pretty well paired. Very linear torque curve.
Had my truck in for the second time for the hard shifts and clunking. The first time they did a relearn. The second time the tech acknowledged the shifting behavior, but said that they discussed with GM and said it was completely normal.
Cool.....
At 4000 miles now 2016 6.2 8spd. Smooth as silk loving it. Somewhere earlier in the is thread someone mentioned that there is no longer a transmission dip stick i will have to check on that. Sounds weird LOL
Update at slightly over 14,000 miles now. 8spd shifts very hard, getting a tire chirp in 2nd 3rd and 4th and 5th sometimes. That is the way i have set the programmer LOL. I may set it back for girly shifts in a few days...... too bad GM did not have the marketing sense to provide owners with driver selectable driving modes. The 6.2 8spd combo dang sure deserves
i have an appointment for saturday morning to address the hard shifting. for the 3rd time... i will keep everybody posted. i am going to bring up the printout from another memeber that identified my problem exactly and they replaced the Torque converter to fix
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,061 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
