7 hours ago, Mr. Carolina said:
Nice! Doesn't look too jacked up and sits high enough for me. I've been looking for one, thanks
Thanks, ya I have an older chebby with a 4 inch and the huge trucks aren’t my thing anymore, this is my ol beast, just use her for work and the nasty stuff lol
Edited by ross001
I’m tired lol
Just joined the club after finally finding the new headlights for a decent price. Had the harness from Vann for awhile. At one point I connected the new headlights and went to grab the bolt to secure it, and the headlight fell and the harness split apart at the connector. So I had to re-wire it, but it all worked out in the end, no issues!
That looks sweet! I got a deal on the passenger side and waiting for one the drivers. Where did you end up buying them?
Off eBay, I'm in Canada and got a nice set from Canada as well. Took months of waiting though.
Edited by roadblock
Looks good! I finished mine a couple weeks ago and forgot to post pics. I did a lot more than just heads and tails but I am pretty happy with how it turned out.
Changed from SLE to A/T Grille
Black GMC letters
Powdercoated front and back bumper
Added Morimoto XB LED Fogs
2017 Headlights and Taillights
Replaced Front Bumper Skid Plate (old one had a hole in it) and added the License Plate Cover
Edited by bwright2112
Black GMC letters
Nice work! Really cleans it up! I forgot to mention I had the Morimoto fogs in already from the group buy. I need to do something with that tow hook surround next. Anyone know if it's hard to get off? Maybe just plasti-dip it as is?
I couldn’t decide if I wanted to leave the plugs in or buy tow hooks but being a regular cab I decided to pass on the tow hooks.
I left mine as it was. Black plastic from the factory. I thought about painting it but I think it looks ok with the flat black on it.
It wasn’t hard to get off for me because I had the whole bumper off ha ha but it does all bolt/screw/clip in from the backside of the bumper.
Now that I am thinking about it though I’m not sure if you can get it off without the bumper being removed. Surely that isn’t the case though. I wasn’t paying a whole lot of attention as I had to remove the bumper anyways but I know I put it back on before I put the bumper back on too and I was looking around behind there and I don’t remember seeing a way to get to those screws. I wonder if you could get it off just by taking the plastic piece above the bumper off though. That would make a lot more sense.
I went on a 2800 mile road trip LA to Coer de Alene Idaho and back in 5 days, in my 2014 fitted with the 2016-17 LED headlights, to pick up a new bird dog. I did a bit of night driving with these LED factory lights.  I’m pleased with the side visibility. They seem even better than the 14 halogen projectors, with a TRS HID kit I had for 3 years, for side lighting.  The forward distance lighting isn’t quite as good as HID in the halogen projector. But it’s still good, and much better than the original all stock 2014-15 halogen projectors.
My opinion of the Rigid Industries SAE fog lights is mixed.  In heavy snowfall, the fogs made it harder to see.  The sharp cutoff of the headlights made the fog lights not only unnecessary, but obsolete.  The SAE fogs do add some side visibility when I don’t want to burn the paint off the back of a vehicle in front of me with my Baja Designs driving lights.
Edited by Spurshot
2015 Denali, I hated the halogen in projector lights and ordered the HID replacements that fit right in the projectors. less than 2 hours to install and less than $200 for the entire kit from RetroFit. So bright you would be amazed! Love them! I also got the super bright LED replacement fog lights that have the same flat on top beam look as the projectors, WOW, 200 % better than stock! They also were under $200 per set. I am now super happy with the light brightness and projection. My son-in-law was so impressed he installed same set up on his 2015 silverado
What kind of fog lights are those? Are they brighter than stock?
I think those are The Retrofit Source (TRS) fogs.  https://www.theretrofitsource.com/assemblies/led-fog-lights/gmc-morimoto-xb-led.html
Stock fogs are 500 lumens each. TRS fogs are 1200 lumens each.
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
