Just wondering if anyone had pre-leveling measurements?
My 2015 z71 double cab sits at 36.25" in front and 39.25". I planned on getting the rc 2.5 lift level, but it seems the front won't be level even before adding the rear spacer. Then I thought about a motofab 3" front, 1" in rear for a bit of rake, but heard 3" might be too much for the front ball joints.
Anyone have a large amount of factory rake (3+ inches)? What was your solution?
Thanks!
FWIW, my 2015 Z71 Regular cab measured 36.25" front and 40" rear on the drivers side. Not sure if you have the aluminum block in your rear suspension like I had, but removing that yields a 1 3/8" drop
Did you level it? Since you have almost the same rake I was curious as to your solution.
There is a lot of information and opinions on this forum regarding your question. I believe that if you level your truck so that the top of the front and rear wheel wells are equal distance to the ground your truck will look nose high.
Ding...ding...ding.. we have a winner. If the top of both wheel wells are level the truck will look nose high. You have to measure top of hood and top of bedrail then look at how much to lift the front.
Interesting. I know everyone uses the wheel well measurements. Guess I'll need to do some more investigation.
You are right that this is "interesting". It is a matter of personal preference and the positioning of your vehicle. Unless you can afford some "trial and error" installs then I recommend more investigation. My wife doesn't always share my "priorities" so I want to get it right the first time! I would go with a 2.5" level if I was adding a 2" block to the rear. (I believe stock block is 1.25"). I would only go this high if I was going to go to 33" tires. I was set (until yesterday) on a 1.5" level with and a slightly over stock tire size. My dealer currently has a truck in the showroom with a 2" bottom of strut spacer and upgraded stock size tires. To me, this is a perfect look! It looks great without my neighbours thinking I'm going through a late mid-life crises!
I'm probably the only person on here who likes the factory rake. It reminds me of my 91 Silverado as they raked them as well.
But as for changing ride height on other vehicles the tape measure only ever comes out once I find a profile I like.
By that I mean I take the tires off set them just off of the studs.
Then raise and lower the back and front until I like it then measure so I can order the parts to give me what I want.
I'm not sure why people buy stuff then decide they don't like it after the fact.
A set of adjustable jack stands and a couple of jacks is all it takes.
here to pic whore.
2.5" rc level. nothing touched out back (lulz)
looks good to me
That does look good. What size ko2, and do you like them? They're on my short list to put on my 18" wheels.
Nope, you are not the only one. I personally do not like the levelled look as the top of the truck box is lower than the hood on this body style. Put a bit of weight in the back and it looks like a dog dragging it's *** on the ground.
If I were to do anything it would be a lift and level with a 2.25" in front and a 3" in back.
love em.
285/65/18
I like a bit of a rake as well for functionality and looks. I also like a bit of height in the front of a 4x4. A little lift (1.5 - 2") of the front end won't reduce your load carrying ability or necessarily cause your truck to squat. If you want to maximize the lift from a level kit (2.5" - 3") and maintain load carrying integrity then rear blocks will be a solution.
  • 5 years later...
Have done some research and wanted to follow up with a question regarding my truck (shown here)...after taking measurements (from ground to edge of wheel well) Im noticing a 3" difference from front & back (36" in front, 39" in the back) and when looking on RC website, it looks like the standard level is 2" -- they also have a 2.5" level kit as well but the price jumps $100
Why is the 2.5" kit so much more money and am I even looking at the right one? Any help from someone who has done this before is super appreciated!
https://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html?find=2018-chevy-silverado-1500-4wd-739610#278=516
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
