I've had the same noise issue since about 5,000 miles, currently at 19 and some change. Dealer visit found nothing wrong and said all noises were normal - well it's not normal otherwise people wouldn't be complaining about it! Anyways...2017 Silverado 5.3L - Faint engine "tick" or light "rattling" or "marble" noise under acceleration. The noise is most noticeable in v4 mode under acceleration and gets louder as you continue to push the pedal down further. Once it pops into v8 mode the sound either disappears or is reduced. Long turns on the highway the noise disappears. Hit a bump or pothole the noise disappears. Drive for an extended period of time (20-30 mins) the noise disappears.
My first guess was the serpentine belt but ruled that one out (I had a ticking noise in my '08 Silverado and it was the idler pulley). It either has to be the high pressure fuel pump system thats located near the firewall banging around or the exhaust system (cat converters). The noise sounds like its coming from the firewall right under the dash near the pedals - I've recorded the sound in that area a few times.
I really think its the cats - the fact that the noise disappears under long turns leads me to believe the cats are being pushed against the casing causing the cats to stop "rattling". Another note - the noise usually goes away completely when the truck has been running for a while (again leading me to believe it's the cats - expanding under heat and pushing against the casing to stop the rattling). Most importantly - where are the cats located - right under the floorboard/firewall beneath the pedals where the noise is most noticeable. Hmm.
Just some ideas here but it's definitely annoying. I'd like to tell GM this but if it is the exhaust system it's not going to be cheap to replace. The OEM Y-Pipe w/ the cats attached go for around $800. Eventually I will replace the entire exhaust system and pray that fixes it. Anyone else have any luck changing exhaust systems (not cat-back systems) please let us know! Thanks!
Edited by kport08
grammer
Mine is constant the past 2 weeks, and most of the summer honestly.  I'm currently at 15,500 miles.  Doesn't matter how long I drive, or going over bumps.  I've gotten it to go away temporarily if I brake really hard, but even that isn't working lately.  The only time I don't hear it is while going around left hand turns.
Mine basically did the light ticking in V4 mode since day 1.  But I bought it in June in the south, so had the AC and cooled seats on full blast and covered up the noise.  Now it is a full fledged rattle/marbles in a can during any application of the throttle. I can replicate the buzzing rattle in park or neutral.
I really need to take mine in again to the dealership just to complain on record, even though I know they can't/won't fix it.  Waiting for boating season to be over so I don't need a tow vehicle before taking it in.
I have long tube headers and an aftermarket cat back. It's still there.
I agree it must be the cats. I am hoping someone will chime it who has had theirs replaced with luck.
I can confirm it's not the cats. I'm Long Tube headers to aftermarket cat back. Entire stock exhaust removed and it's still there.
Has anyone tried a heavier weight oil? I noticed you can barely hear the ticking and rattle in the winter time.
Agreed - it's been to the dealer 4x for this issue.  1st time they replaced fuel feed line, 2nd time they replaced fuel feed pump, 3rd time they replaced the entire exhaust, 4th time they said "it's working normal".  I finally fixed it by trading it in for a F150  :-/
This will be my next step. 2018 F150s look good but that 10 speed has me skeptical.
Fords seem so expensive to get a comparable trim package, at least where I live.  Plus I hate the interiors.  I was ready to pull the trigger on trading in my GMC for a 2018 RAM earlier this summer, but it was built so poorly I couldn't do it.  Inside and outside was chintzy.  Although the engine sounded nice...
I agree. To get little things like 4-auto and auto HVAC you really have to pay. And I really dig the new 2019 rams as well.
My 15 Sierra has a tick to it almost sounds like a old model A running. I'm at 38,000 no problems. My buddy has a 14 Silverado sounds the same he has 95,000 on his no issues. I do think that's just how they sound.
I can't agree.  The loaner Sierra's I got (similar trims) didn't make that noise.  Test drove another Sierra denali, no ticking noise.  That speaks to quality in my book... The fact that there is a PID to resolve this issue (even if it doesn't) tells me there is problem.  One of the reasons I got the truck was for the quiet cabin...  maybe if it wasn't so quiet.  :-)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
