If you get a chance to look at your invoice when you get your truck back, please share the part number of the gear installed on your truck. Thanks!
XU and Retired..
My part # is 84224694, sorry I didnt see it before on the invioce. Hopefully this is the new box, I have put my leveling kit, install on the back burner till I see if this box fixes the issue, so far so good, 2400miles.
I have the same issue with mine, except I have purchased one out of my own pocket because my truck is lifted.
Dude, did they tell you it was because of your lift?? Thats chicken poop, did you go to war with them?
XU and Retired..
That is the same part # I ordered....whew... I am hoping this really does fix the issue. To remedy the play a bit further, I ordered a pitman and idler support kit from Cognito. Glad your steering is working good so far
I should use the Magnuson Moss Warranty Act but I do not have time to haggle with them. At least this part is considered an "over the counter" part, so if it fails it is under warranty no matter what aftermarket parts the vehicle has installed. Edited by XU_Design
What size is your lift?
I have been working with GM Corp. and starting to get a resolution after they told me to remove the leveling kit that was installed by the dealer I purchased it from. If you have the time to work with them, I would since this issue is a hit or miss on getting resolved.
Now when it comes to the lift, they told me it was the cause and to make sure it wasn't they told me to remove it by a dealer and have a dealer test drive it and confirm that its still having the issue. As you can guess it still is. I will be fighting this all the way up to the top if needed since clearly other owners are having the same issue with no lift or level.
From what I have gathered from legal sources that have been to trial with dealers and auto corps before, they will not make a recall until something fatal happens due to that component. This is unfortunate but seems to be that way.
One last thing, I have had my truck at 4 different dealers GMC and Chevy and they both say the same thing "We have never heard of this issue or the TSB's". Can some one explain that to me since this seems to be a common thing.
The fatality thing doesnt make sense, I mean my 07 was recalled, one time for wiper heaters... anyone die from wiper heaters?
My service writer is a great dude. He told me when I called, this was the fourth or fifth truck to come in for this problem. Then, when I came to pick it up, the head mechanic was standing there. First thing he says is, "Your the first one I've seen". Service writer looks at him with a queer face, and says, "Noo, we've done a few". Mechanic pauses, and looks puzzled,"Ohh, yeah, maybe, yeah, well your lucky, it was free". Haha
That is the same part number that was in mine. 1500 miles and no issues. Hopefully it stays that way.
So I just got the OEM steering box, new part #84224694 from GM. Hoping this is revised from my original.post-166741-0-13884900-1482359951_thumb.jpg
I wonder if we'll ever find out what the actual "failure" is? XU, had the dealership performed any of the other TSBs or did they go directly to the box replacement?
Seems sort of pointless for owners (down the road) to go thru the "alphabet" when they may have been superceded by later TSBs.
Edited by revrnd
They won't touch my truck. They took one look at it and said they would not even ask the regional tech.
Bummed, but I am a builder/fabricator so not afraid to do the work, just can't believe a 70k 3/4 ton truck is having such major problems. I only have 10k miles and this problem started BEFORE I lifted it.
When you do the R & R, compare the feel between the boxes. I'm wondering if there is premature wear (causing slop) between the cross shaft & power piston nut?
http://www.pirate4x4.com/forum/attachments/testing/941042d1372393582-ill-just-put-here-86-88-toyota-ifs-box-exploded-diagram.jpg
This may explain why the early fix included readjusting the "lash". I doubt many of us have ever had this adjusted in the past. Other components may wear out in the front end, but when they're replaced the steering is as good as new.
The dealership called me back today. They said the truck is good to go. They service writer stated they retorked the screw and tightened it back and said they used Loctite to keep the screw from backing out again,hopefully this is the last time it has to go in for the same issue
Hi thinblueline,
We are happy to hear your dealership was able to resolve your concerns. Should you have any future questions, please be sure to send us a private message.
Sincerely,
Brandon J.
GM Customer Care
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
