How will you choose your first car?
Hi,
I am going to get my first brand new ford truck. My friends suggested getting Ford F-150 XL truck, as my budget is low. What are the factors you would consider before buying a truck? I have gone through articles for tips for getting a truck. Is there any need to install additional features? How will you buy choose your first car? Based on the reviews or from your favorite brand?
First, ask your parents how much money they will give you. If not at least 50k, throw a fit until you get it. After that, just go pick you out a Platinum Edition or King Ranch and enjoy high school in your new truck like every other kid. No kid ever settles with an entry level truck these days.
pretty much you pick out a truck you like for the budget you have. then you go spend thousands of dollars on new wheels, lift kits, mufflers, etc. haha.
are you using it as a truck or as a status symbol? no one can tell you which truck to get besides you.
(though I would suggest not looking at anything with a blue oval on the front.)
I miss the days of my old 89 S10 work truck and 87 turbo coupe. High school was great. Instead of 1 nice car, i had 2 cheap cars
My first question is why are you on a GM truck forum asking about buying a Ford? I mean I could care less what you buy. It's just that it's a little weird to come on a different brand forum to ask about buying a different brand so you probably should be on a Ford forum. I know your question means the same no matter what brand. I just don't know why you joined and asked a question about buying a Ford on a GM forum. Now if you were trying to pick a brand and asking on different forums that's understandable. It's just that you specifically said you want an F-150 since it's what your friends suggested.
Personally I've always had Chevy, but all of the "Big 3" have their plus and minuses.
Anyways, you need to figure out how much you can spend first and then go from there. Then you figure what things is a much have and maybe pick some out of that list that you could go without if you had to. Being still in high school, I wouldn't hope for much unless your parents are going to buy it for you.
You start with a budget. If this really is your first car and you're still a teenager, I'd HIGHLY recommend against a new car or truck. Get a used one, learn how to work on it, and save up your money until you figure out what you're going to do with your life. A new vehicle is one of the worst financial things anyone can do. Some folks do it because they are well established financially, but someone in in their teens shouldn't even consider it.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
