2016 console lid with powermat swap
The more I look at this and compare to my console lid, the more it looks like a match. Would this directly bolt in with my 2014 Silverado bench seat console lid? I'd love to add wireless charging, and this is cheaper and cleaner than brand motions option. http://m.ebay.com/itm/401130622095
I'd be interested in doing this as well. There has to be a harness that you would need as well though
Not sure but it states 30 day returns...so order it up and try it out, worst case it doesn't work and you can send it back
Can't say I would recommend the OEM charger unless you have a Galaxy S6 and then probably without a case on it.
I bought a brand new S7 Edge on July 4th thinking it would work with the brand new truck that I was getting the next week...WRONG!!!!!! :(
There are plenty of threads out there about how the charger doesn't work with various phones.
Although... I ***CAN*** get it to work with my S7 Edge providing the sun is in the west, I take the case off, turn it around and have it face the back of the truck, push it ever so slightly up onto the rear lip, put my left index finger in my right ear, hold my right leg up, (while I use my left leg for the gas pedal), face the east, don't go over ANY bumps... and touch my right ear with my tongue!!!! LOL
I kid you not!![emoji15]
Had the tech try and get it to work and he couldn't. Then he popped his S6 (non edge, no case), on the console and HIS charged, so I was then informed "It works".
Me thinks NOT. :(
Something about the newer phones needing a stronger charger.
I know I can get my S7 to charge in the Samsung charger in a thin case, and in a REALLY bulky Otter Box. Even upside down!
Sent from my SAMSUNG-SM-G935A using Tapatalk
What a bummer. Sounds either very gimmicky or Chevy didn't consider charging requirements for newer phones. I have an iPhone 6S+ which requires 2.1amps to charge adequately. Which this wouldn't work for.
GM was one of the first to introduce this. Great thinking but I don't think they thought about it that much. It's a pos system that don't work. I've tried apple and Samsung phones. I got 2% charged for a 2 hour drive.
"Does not ship to Canada" :bs: It is a scam obviously
The persons store does seem to have a lot of ACdelco and OEM stuff though. Could be legit but I am always paranoid of ebay lol
I would check out this person mod where they just added wireless charging to a stock console lid themselves. Looks easy and straight forward but I think you sacrifice a USB slot. (Protip: there is another USB in glovebox many people do not know about)
http://www.gm-trucks.com/forums/topic/169848-3-coil-wireless-charger-install-in-2015-sierra-denali/
*Careful of 30 day return policies on Auto Parts they almost always carry a restock fee of 20% or more.
You do realize that GM cant control wireless charging. The standard is not really set on it yet, example is the first gen of Samsung wireless charging phones and pads couldn't handle a fast charge like the plugged in cable provided, now on the S7 and up they fast charge on wireless just as if it was plugged into the cord.
The standard is ever changing, no way for the manufactures to keep up with it.
Yeah the more I look, the more I'm going to go the diy route. If the charger bugs out, it's cheap enough to replace it.
Just like the sun glass holder above. Way too small.
Right?! Who the hell tested that thing out and was like yup, it works... Lol [emoji849]
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
