Chris, do you know if I'll have any issues just running the Denali cluster by itself after you do the programming to it for my Yukon and the HUD functionality?
I'm currently looking for the correct connector and wire terminal part numbers for the HUD connector and HUD switch that mounts in the dash, but would like to go ahead and install the cluster once you're done with it.
Nope it'll just have a code (no check engine light) from lost comms with the hud I've done a few of these for people who have gone that route.
Trying to contact you to program a used one for my 2014 SLT. Couldn't send you a PM
Correct our pm are off please contact us from our website thank you!
Sweet, thanks Chris. Do I need to send the cluster and HUD unit to you to do the programming or just the cluster?
Edited by cmatt
Where is everyone finding the HUD units and related parts? Are they year specific also?
Sent from my SM-G935V using Tapatalk
I made sure to get the correct part numbers from the dealer and found everything so far on eBay. What I found was sold as new condition and appears to be so after I received and inspected them.
Edited by cmatt
Just the cluster, the HUD is a slave to the cluster but won't work until we program it :)
Damnit, there is a HUD?! I've been trying to keep from spending more money on this kind of stuff!
Yes but you'd need a Denali cluster to drive it; update time? LOL
Would this work with a 2017 Tahoe Premier gauge cluster to swap to a Silverado? The Tahoe Premier cluster looks the same as the Denali cluster.
I knew I should of just gone straight to the Denali last year. Damn my self control! I am going to add it to the list, but put it towards the bottom, I have some other irons in the fire still.
Does anyone have the part #'s for the HUD unit and wiring needed? I'm sending my cluster in to get programmed on Monday. 2017 Sierra Denali. Thanks
It's in one of my previous pics above. The wiring is part of the I/P harness. I'm working on finding the connectors and will create a custom pigtail.
Just confirming...will this fit in a Sierra or Silverado? The part description shows Suburban/Tahoe/Escalade. Where does the unit and switch mount in a pickup with the different dash configuration? Just doing my homework first before spending the money..Thanks
Apparently it does we've programmed quite a few clusters for it. Have not first hand seen one but they exist from what I'm told lol
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   0 Members, 0 Anonymous, 587 Guests (See full list)
