I have a '15 Sierra with approx 30,000 klm's. I have twice noticed what looks like steam coming from the front of the hood and grille area. Nothing feels hot, nothing leaking and engine temp stays normal. Has anyone one else noticed this?
Also had the headlights done with the bulb replacement in March 2015 and have already replaced the two headlight bulbs due to them blowing out. Anyone else had this problem.
Thanks
My truck has done the exact same thing a few times in the winter/fall when it is cold out. 2015 Silvrado 5.3L. No issues with coolant being low...but strange indeed.
**I had a buddy who had a small crack somewhere in his radiator on a 2014 GMC sierra, whole rad had to be replaced.
I had this problem on my 2014 Chevy Silverado and they had to replace the radiator and the cost if it wasn't under warranty would be about $1,000 using OEM parts. There is a service bulletin on it because of corrosion issues. No recall yet.
Edited by PMattras
Rick,
I had the headlight bulbs replaced in my 2014 around March 2015. Both blew in less than 6 months.
I replaced them myself and have had no issues since. And it's a year since I did it.
I put it down to too much handling of the bulb by the mechanic. But it's still $90 CDN
sam :-)
My brother's 14 had this around 40k and needed a new radiator. If under warranty take it to the dealer. It should not do that
Had the same thing and it was the radiator. It was a known issue to the dealer. I could not find a leak but was a little low for months. I did smell it. They found that it seeps out a crack on the side near tanks, it is a stress crack. Apparently the fix is to replace the radiator and thermostat as the old thermostat cycles too much causing the crack?? Flush, radiator, and thermostat----warranty!
My 2015 GMC did this from day 1 when I purchased it in the winter. Noticed it on wet/cold days. Dealership service manager was unaware of the issue. Hasn't done it all summer so we'll see once it gets cold.
There's no visible leaks, cracks, etc for mine. I think it's due to the wide open grille style of the trucks, but it's rather annoying. I was on the highway in the sleet/snow getting road mist from behind a dump truck and when I exited and stopped it looked like my truck was overheating.
Edited by royalkangaroo
While these trucks have had a radiator problem, I believe all you are seeing is the cold water hitting the hot radiator, trans cooler and condenser. It is nothing to worry about, my truck does it along with every other car I have ever driven in my life. Even if it is warm outside if I drive in the rain and then stop at a light where it is it not raining I can see steam coming from the front of my truck. It is not a big deal and would not worry about it unless you smell coolant and / or see a loss of coolant.
As whitestallion posted don't confuse "normal operation" concerning this, with some sort of leak. If there isn't a coolant smell don't worry about it. I asked this same question back in 2014, and pretty much got the same reply as whitestallion's. My truck has done this from day one when it's warm temp, damp and rainy, and cold temp and precipitating. I've actually got out and smelled it. Nothing but water vapor.
Exactly. Does it on my 16 anytime it is raining our or snow etc. It is getting splashed on something that steams it away. Not a worry for me.
  • 2 years later...
I know this is an older topic however I just had my radiator replaced because of the steam issue. They also replaced the thermostat. GM knows this is a problem. During the replacement of the radiator the tech noticed severe corrosion of the A/C condenser also. If your trucks are under warranty I would suggest getting these things looked at. My truck is a 2015 High Country. My Son also has a 2015 Silverado and had the same issues with his. My Son has a friend that is a GM tech that stated the have replaced many radiator / thermostat and A/C condensers. in our case you have to remove the top shroud and look in the top corners the see the leaks and corrosion. I have noticed the steam for quite some time and thought it was just moisture / condensation but when i saw the steam on a very dry morning I thought I better have it checked. I also noticed it during car wash / rain / snow.
Edited by shaddow1987
I have a 2017 Sierra that for the past month I can smell coolant every time I walk by the front of my truck. I'm not low on coolant, can't see any leaks and haven't ever noticed steam. I know my dealership will just say its normal as they have with almost every issue I've had. Do the bad radiators and thermostats extend to 17s?
  • 2 years later...
Was this a power train warranty??
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
