Personally, I didn't like the Philips. The light was whiter, but not brighter since there are no LED pieces on the distal tip in the bulb. I ordered the JDM white LED lights and love them for reverse lights. I can see so much farther and behind and around the sides backing up. I HIGHLY RECOMMEND USING THE JDM BULBS!! For bed lighting, I ended up just using the Phillips bulbs since I already bought them and didn't want to piss the money away. I don't use that overhead lamp much, so the Phillips work well enough. The Phillips license plates lights look good too.
I bought the JDM's on your recommendation for the reverse lights, which I love but I also bought the Phillips for the brake lights and was not impressed. I am going to send them back to Amazon and get the JDM's for the backup, front turn signals and the cargo light. The JDM 800 lumens were quite bright and didn't need to pay $10 more for the 1200 lumens.
Touch more then 50 but I call it the tug box the 50 was 50 itself ce4399437b965e47777d4699ebc9b511.jpg1c9d97ae25190885f8078115a48004c9.jpgdcda3bd404830cdb49333bbf43fbc89b.jpg434f2123757c1ec788f115dd8b32e98d.jpg
Canadian winter is coming so figured I needed something for my stuff
Sent from my SM-G930W8 using Tapatalk
Do you have a link for this box?
Unfortunately no link because I bought it from a local store they just happened to have a bunch at the door they ordered
Darn it good point! I crumpled and tossed out the extra pieces lol
do you have the ebay link?
Good luck with that. Jdm leds are cheap and burn out all the time. Id stick with some name brand ones for the peace of mind.
Do you still have the link?
This is the one I bought and it came with two pieces for the both emblems. With the left over i could have perhaps done the steering wheel and z71 but I just re-ordered more :)
http://m.ebay.com/itm/161953750934
Edited by asalinasz39
Sure I'll try, haven't posted a pic on this forum yet, but here goes.
Go to Amazon or similar and order these:
1N4004 400V 1A Axial Lead Silicon Rectifier Diodes
You only need one really but order 25 as it's just as cheap once you take into account shipping if you try to order just one.
Plus if you bend or break the one diode, you have back ups.
Then you'll look under your dash above your gas pedal. You'll see a bunch of small power blocks inserted into a larger one.
You want to locate the BROWN one.
At the top you see a release latch. Go ahead and push it in and pull the small BROWN electrical block out of the larger one.
Twist it around so it's oriented with the release latch up.
Using the diagram in the picture I've attached, locate pin/cable slot #10. It's obviously 2 slots over from #8 that's marked on the diagram. Insert one end of the electrical diode down into that #10 slot. If needed use a needle nose pliers. The diode pins are pretty bendable so just make sure you get some of it down into the #10 slot.
Then go down to the bottom (last row away from the release latch and go to slot #22 (clearly one over from the #21 that's marked in the diagram).
Push the other end of the diode down into the #22 slot.
Once you have them both in the #10 slot and the #22 slot, you've made a jumper "bridge" between the two.
Gently twist the BROWN electrical cube back so it's oriented and push it back into it's motherboard. It will click back in.
Insert key in your ignition and test it out.
You're FOG LIGHTS should automatically be ON if your low beam headlights are ON.
When your low beam headlights are OFF, the fog lights will also be OFF.
You can now just leave the dash mounted headlight selector in AUTO and your low beams and your fog lights will both automatically come on each and every time your headlights come on, and go off when the headlights go off.
All done.
Thanks for this! I just got my diodes tonight so will put one in tomorrow morning.
Frame Plugs
Caps that cover the holes and keeps dirt, mud, critters from getting in there.
Got these an they really clean up the look of the rear of the truck, thanks for the suggestion
  • Like 3
Phillips 921 LED / T16 (12789LPB2) Bright White Vision LED - 2 pack. You'll need 2 packs for a total of 4 bulbs.
Phillips 194 Bright White Interior for the License Plate bulbs - 2 pack.
Both sets of these bulbs are 25% off right now at amazon. Have to place separate orders though.
Did you guys self install the driver assist handle? Dealer wants to charge $100 for it
Wow, I'd love to charge someone $100 to install that handle. Took me about 25 mins and that was being extremely careful and being interrupted.
Just got these installed they look so much better than stock because they are a true white instead of the yellow, in terms of the backup light output i noticed a slight improvement in the camera view, but I am not a good judge as I just got my driver and passenger windows tinted today too...needless to say that has a little bit of an effect on it..haha
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
