So I'm new to the site and working on this swap. I already have the steering wheel with controls & new cluster from (WAMS). I'm looking for clarification on two of the steps referencing  "TAP"
#7 (Radio) to #5 pin (cluster).
#2 (air bag) plug to #20 pin (cluster)
Am I adding a wire?
t- tap connector the original wire and running additional wire?
If I'm adding a wire where can I get the correct pin for the plug
Please forgive me for my confusion I'm struggling to wrap my head around this process
Thanks in advance for all of the help
Vinny
  • 4 months later...
On 2/7/2020 at 1:48 PM, Todd1982 said:
Just saw this ...
I finished all this back in April of last year...
I thought i posted in here the functionality of each wire .
The information being sent to the Dash is over the MOST Bus the alpine does support MOST Bus
If you recall during the install you removed that plug and never plugged it back in.
Let me know if you have any more questions
Tod, so there is a way to link the maestro back to the cluster to display the radio info on the cluster?
  • 5 months later...
I have a W/T and have upgraded the cluster. I have the right thumb buttons working the steering wheel to cluster. How can I get the Vol up and down or the seek button to work? Could you tell me which wires to tap into if you have the IOB unit?
thanks
  • 5 months later...
I have the 2018 Duramax Regular Bed Crew Cab WT, Only Cruise Control On My Wheel. I Bought the wheel with heat, Audio Controls, Dash Controls. Purchased the denali cluster from WAMS, the wheel clock spring. i have the IOB Radio 7" screen. currently looking at pinouts but none of the circuit numbers match up, trying to decipher if it is doable with the 7" IOB. any input that may help out?
I have the IOB 7” screen in my 2019 2500 w/t. I’m wanting to upgrade the instrument cluster and the radio to the 8”. Already have the upgraded steering wheel (no heat) installed with only cruise buttons working.I have the upgraded cluster as well. Is this possible at all?
Check out https://www.whiteautoandmedia.com/
They will let you know if its doable.
Edited by MikeBMW
  • 11 months later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
