Rear Tailgate Camera 2016 8pin to 2014 6pin connector
Rltports
I had purchased a replacement GMC camera for my 2014 1500 SLT Sierra to attach to my truck camper. It worked great. I recently replaced that truck with a 2016 2500 SLT Sierra. Unfortunately, when I went to plug in the camera which i had attached to my camper, I discovered that GMC had changed the connector. The 2016 2500 has an 8 pin plug while my 2014 1500 had a 6 pin plug. I am assuming that my camera from the 1500 should work with the 2500 truck if I can find an adapter. Is there a good source to confirm and to assist with providing a solution?
There is no adaptor from 6 to 8. You can't make up for the missing 2 wires. Your new truck is missing the towing option that would give you the 8. Best choice is to have an aftermarket 8 round installed with a T connector.
Any idea where I can find a wiring diagram showing the pin and wire color use for the 2016 2500 rear camera connector and one for the 2014 1500 rear camera connector? From reading other forums it sounds like GMC may have combined the auto tailgate lock into this same harness on the 2016 model which would account for the extra two wires. If so, my hope is that I can still utilize the 2014 camera. Just a thought.
Thank you SK, I was able to find the electrical diagram for the 2016 but not the 2014 truck. I may have enough info to resolve the issue and rewire the camera from the 2014 truck. Thanks again
  • 8 months later...
Thank you SK, I was able to find the electrical diagram for the 2016 but not the 2014 truck. I may have enough info to resolve the issue and rewire the camera from the 2014 truck. Thanks again[/quote
Did you ever get this working cause you can buy and 8-6 pin harness for this to work I have one on my 16 Silverado
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
