After seeing all of the disgusting cabin air filter pictures, it would be nice to head this off. Does anyone know where the air intake location is ? Just got a 2016 and being in a heavily treed area that is full of rodents of all sizes, would like to make a screen to pre-filter this air. Thanks.
No way a rodent is making into that intake system. It is on the wiper cowl.
Did it get changed for 2016 ? All the posted pictures speak for themselves, MICE, LEAVES, STICKS, could start a campfire with all the stuff collected off the top of these filters.
That doesn't fall through the grate though. If you've got sticks and mice, they aren't coming through the cowl plastic screen, they are coming in from under it right through the intake sheetmetal. And they will probably get through the screen too lol.
Edited by 15HDriver
I see this thread died but wanted to reopen the question. I just purchased a 2017 sierra crew 1500 slt. The last truck i bought (which i still own) was a 2006 lt3 Silverado crew with the duramax. I live in a wooded area and have had major mouse issues. My 2006 was a haven for mice. To this day i have never found how the get into my cab. And am worried they will get into my new truck. My 2006 had no cabin filter so i tore apart the cowling only to discover the intake was already screened so the mice were not getting in through there. In my 2006 however large the opening its big enough for a mouse caught in a glue trap to still pull himself out (this has happened twice) without me being able to find him. The only logical opening was the rear body vents that exot between the bed and cab but that is the one place i have never found them. Side note over the course of 2 days last year i caught 11 mice in the cab of my truck.
My wife has a 2014 sienna with car seats and lots of food crumbs from the kids. When we first got it the mice started getting in. But i found that the air intake was not screened. I put a wire mesh over it and since then have never had another mouse inside.
Would be nice if there was anyone who could advise the potential openings for mice in these Silverados and potentially the new sierras. Btw i own a car lift and have had my truck in the air and not found the entry point.
Cab fresh and dryer sheets under the hood don't really work either.
UPDATE: Just last week I was cleaning out the last of the falling leaf debris, getting ready for winter, when I noticed a squareish rubber plug with 2 nipples on it, laying loose by the fender and the battery. Not having any idea where this thing came from, got me to looking. Turns out both ends of the firewall, up top by the black windshield wiper trough have these flapper type vents, like the type in the back of cab. The passenger side fell out, thats what was laying by the fender. With a mechanic mirror and a light could see where this thing goes. Reason it FELL off is, holes are too big, or nipples are too small,or both. Was fun trying to get these nipples back in the holes blind. ONLY TO HAVE IT FALL RIGHT BACK OUT. Some silicone adhesive fixed that. Now with that rubber plug out, the whole mouse family could dance the jig as they went through there. I KNEW there had to be a way people were getting those mulch piles on top of their cabin air filters. I found mine, yous may vary.
Good info. Having mice get into the vehicle much less chewing up the wires inside or out is a huge issue for many.
Did you happen to take a pic of this rubber plug? Is your truck a 2016 1500? Sounds like you may have stumbled onto a possibly important issue here Mr SwampThing..
S
sounds like you need some outdoor cats. That will fix your problem.
Wow I'm glad I saw this thread and comment. After just 15k miles, garage kept, this filter is still dirty as hell.
The filter doesn't get dirty by sitting it the garage, it gets dirty when you go out and drive it :cheers:
did you stage that pic by putting dirt on that filter? haha that is disgusting
Haha, yeah I reread some of the posts here, and my idea of how leaves get into and on the cabin air filter was quite wrong. I pictured a vehicle sitting outside somehow being more prone to crap falling in,, but that isn't how that works lol.
Edited by 2015_Sierra
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
