So this is an older topic but in my search on the internet seems to be a fairly common problem that maybe GM needs to do a recall on?  I have a 2016 GMC Sierra and just noticed today that my washers don't work.  Fuse is OK and I don't hear the pump run when I turn it on.  So looking like I need to replace the pump.  I don't think I have ever had to replace a windshield washer pump on a car in my life let a lone a 3 year old vehicle with 30,000 miles.  Unfortunately my warranty was up in May due to time.  So I get to fix it myself.  Seems like a cheap enough part and maybe that's the problem but it that many are breaking I would think GM would take a closer look.  Either way, does anyone have instructions on how to replace this?  Looks like I get to tear some stuff apart to access it.  Thanks.
I did this to my 2016 almost a year ago. The pump sits below the water reservoir tank. You’ll need to remove the driver side headlight. The pump I used actually came from @Tinkering Fox (Thanks again!).
It was a simple fix. I’m guessing if you run these pumps without fluid for a long time, they will fail.
Good luck!
I have a 2015 LTZ Z71 with 41,100 miles and noticed no washer fluid on my way to work. Reservoir is full so I assume pump as well. Can't say I've ever had this issue with any other vehicle. Of course warranty is expired so thanks GM for making sub par trucks!!! I should have kept my '99 Silverado. Seems like that was the last time they made the "most dependable, longest lasting trucks on the road".
2016 Silverado - I hope people are still seeing this thread lol.  I replaced my washer pump (twice in two days to rule out a defective replacement), checked the fuse. and blown though the hose to make sure it isn't clogged.  I checked for voltage at the washer pump connector and it's good too. I still don't get anything when I try to spray the windshield.  Is there another fuse/relay/other electrical item to check?  Thanks in advance!
Edited by John Knisley
You have 12V on one pin, do you have gnd on the other?
Went to use mine on the highway, didnt work then smoke started pouring out from under the hood.  I happened to be headed for an oil change and my mechanic put fire out but it was caused by the windshield washer pump! It did not even trip the fuse just caught fire burned out pump and wiring harness. Very scary cannot believe this happened on, of all things a windshielld washer pump. Its not like its really used that much, people dont ride around using it every bloody second and for it to not only fail but catch fire, come on GM! Step up!
I have a 2016 GMC Sierra and my washer pump has went out also.  It is full of fluid and the motor will not run?  Why isn't this a recall or covered under warranty?  My truck is a 2016 and has 35,000 miles on it..
It is covered under the trucks warranty if your truck is still under the warranty period/mileage.
It doesn't appear to even remotely come close to qualifying for a recall, neither for frequency nor safety.
Just adding to the pile. I have a 2016 1500 ltz 56K and my washer pump just stopped working as well. Is it just me or are there a lot of fit-n-finish issues with Chevy Trucks now? I saw earlier in the post a gentleman wanted to get his '99 back because Chevy isn't producing the same level of reliability. Got to be honest with all the little issues I've had to fix and poor performance from a 5.3...Ford will be my next truck. Yep, I said it, but unless Chevy ups the game why would I buy another Chevy car or truck?
A part failing after 5 years is not a "fit-n-finish" issue.  And dropping the brand because of it, well, you probably will run out of brands to buy from relatively soon...
  • Haha 2
Good luck with the Ford, maybe they will let you install the "chips" needed yourself, rather than the dealer doing it for you.
Should be a pretty reliable rig🤔 Report back when you hit 56000 trouble free miles....
Interesting, I'm a bit past B00BS (80085), 80222 now - had to update my drive safe and save app - and, so far, all has been trouble free.
Still, fingers crossed!  🤞
Edited by MikeBMW
  • 2 years later...
Old thread but the pump on our 2015 with 110,000 miles just stopped too.  Looking at Youtubes it looks like most people are removing the 2ndary battery tray and some of the fasteners on the DS inner fender well to get the tank out and replace the pump.  I see someone said on a 2016 you can go through the headlight opening, is that to get to the pump without pulling the tank? Whats the best way to get to it?
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
