Anyway to fix Chevy Lean?
I noticed my truck has started to lean to the drives side out of nowhere. It was straight as an arrow since day one. Last week after a long 3 hour ride, I started noticing my truck leaning. Thought I was crazy at first, then I measured it and surely enough it's leaning 1/2" on the driver's side. Tire pressure is good on all tires. Any suggestions on how to fix this?
  • Replies 38
For as long as I knew Chevy has had that lean and it's just from the gas tank being on the driver side. Don't worry about it. Or just always have someone that weighs the same as the current gas level in the tank.
Thanks for the reply. The thing is, it wasn't always like that. It just recently started learning. I would have caught something like that if it was like that since day one.
I'm pretty sure it had always been like that and you just now noticed it. You might think you would have caught it, but you probably just didn't notice it until now. There's going to be a lean since the gas can weigh as much as 180 roughly for the full 26 gallons.
You can try jacking the truck up on the lower side. Let the suspension come to full extension and then drop it back down. Don't know if it'll work or not but maybe the suspension just got a little bound up
since no one else is helping, maybe rather than dating a "fat chick", make it a right hand drive. your body weight on the right side should level it. you could also try a strut spacer on the drivers side, in theory it should level from front to back, front left, right rear.
I read about the Chevy lean a few moths ago and measured my truck several times in my driveway and found my truck had a lean. I mentioned it when I took it in for service and we measured it on two different surfaces in the shop. Both of these times it came out even height on both sides. I suspect that unless you have a perfectly even load and are parked on a perfectly flat surface, a 1/2" height discrepancy isn't a flaw.
most streets are crowned. So if your drivers side is closer to the pavement, your truck is actually sitting level while cruising. :driving:
Some good solutions, but they require a compromise of principle (dating fat girls) or cost money (new shocks, installing spacers). Meh, just tilt your head to the right.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
