2014 GMC Sierra 1500, Last night I got into my truck and neither my high beams or low beams would turn on in my truck. The fog lights, turn signal/marker lights, and tail lights all work. I tried auto and on on the switch. I tested for power at the headlight fuse and did not have any with the headlights turned on. The light on the dash turns on indicating that the headlights are turned on.
Any ideas where to look? I cant seem to find anything that shows where a headlight relay is. What links both high and low beams other than the BCM? Of course my truck is 4000 miles out of warranty.
Any help is appreciated! Thank you.
F.Y.I. The high and low is only 1 bulb per side. The GMCs have a shutter that covers the bulb slightly in low mode and when in high mode the shutter moves up out of the way and exposes the whole bulb to shine through the projector lenses.
Hello Nate,
We apologize for this headlight concern you’re experiencing! Feel free to send us a private message including your VIN, and we’d be happy to assist in the best way possible.
Regards,
Anthony
GM Customer Care
On 11/28/2016 at 9:32 AM, GMCustomerService said:
Hello Nate,
Regards,
Anthony
GM Customer Care
Did you get this resolved? I'm having the exact same issue with my 2015 GMC SIERRA.
Hey, did you have any luck with this? I'm having the same issue.
Did you have any luck resolving this issue?  Both of my headlights quit working this morning,  bulbs are both good, fuse is good, etc
I have had the exact same problem as Nate. Did this get resolved?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
