Denali Transmission Temperature Gauge
I have looked everywhere through my gauge cluster and cannot find a trans temp page. If I press tow/haul I get a small gauge that comes up on the screen, but it isn't very accurate. My '15 SLT had a page with the trans temp, but my '16 Denali apparently does not. Am I missing something?
You can pick a screen that is similar to chevy dashboard and when you press the T/H mode the entire right gadge changes to tranny temp.
Did you go into "info" and select the trans temp option?
Yeah, I've tried. But there isn't anything there about transmission temp.
Right, but there isn't anything you can read with any real accuracy. My SLT had a specific page with a digital readout.
:wtf: How do you know it isn't very accurate? If it isn't, why do you want a bigger one of the same in accurate reading?
Tyler
I think what he means is the DIC page provides temperature in 1 degree increments, but the 'gauge' display is like the water temp gauge with only a few increments between the min and max.
This would make it lower resolution, but not necesarily any less 'accurate', since it will get the info it displays from the same place.
Question for the Denali owners -- is there a 'red' zone on the display, and at what temperature?
Tyler
I believe I have mispoken. The small digital gauge is not very precise. It may be accurate, but it has very low precision compared to a digital readout.
With the digital readout I could measure within one degree. With the small gauge I believe I would be lucky to be within ten, maybe fifteen degrees from actual temperature purely based in it's scale, size, and resolution.
Denali owners are too important to concern themselves with such irrelevant data.
Hold up I will be back after while, I have to run get some Grey Poupon Dijon
I personally requested that the guages be removed from my truck altogether.
I know what your saying but 1° here and 1° there is really not going to matter.
I tow a heavy load once in awhile and i just glance down and make sure it has not moved much.
That is correct. I've tested it many times against a scanner and found it is indeed very accurate (unlike your water temp gauge which will read exactly 210 degrees from 180 something to 230 something actual temp). But, it's hard to read precisely. If you work out what the marks mean beforehand and remember them, then you'll be able to tell within a few degrees pretty easily but it would have been nice if they'd labeled them better.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
