Goodbye WeatherTech, Hello Husky
UrbanRage
What's sucks is the best fitting and materials used are the gm. Would be perfect if not for that stupid cut out. I just returned the husky x act because the cut was to low along center console so ordered weather tech. They cover better but too stiff. But willing to compromise for coverage. Too bad weather tech doesn't update there material to something like husky. Going to try and cut and glue a patch unto gm ones . Just bought a cheap mat from auto zone to try. Hopefully turns out well so I can return weather tech.
Sent from my SM-G920V using Tapatalk
  • Replies 49
I just bought a set of these for our 2017 Equinox, and they are more of a thermoplastic than rubber, a lot thinner than I expected (had old versions of WTs way back in the day).
They fit great, almost too well because you keep trying to get them perfect. The Wife commented they are slippery when wet...figure a little dirt will solve that problem. They cover well.
And yes, they are Husky weatherbeaters...
Sent from my SM-T350 using Tapatalk
I had a set of the weather techs in my 15. I found that they were slippery when wet, and warped after a period of time. I bought the husky x act contours for the 2500, so far they fit perfectly and aren't slippery when wet. As far as coverage they aren't as good as the weather techs but they are still really good and keep the carpet cleani. I recommend the Husky x act contour mats and would buy them again, the weather techs I probably wouldn't.
I sent back my weathertech after they came in the mail. Just looked shitty. Ordered the husky and couldnt be happier, plus got the set for close to 50 bucks cheaper.
Sent from my SM-G900P using Tapatalk
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
