Goodbye WeatherTech, Hello Husky
UrbanRage
I have Weathertechs up front and i too have thought about switching to the Husky X-act contours. My issue with the WTs is the passenger side liner slides around and both liners channel water out the side over the door sill rather than hold the water so you can dump it out. It creates quite the mess. My only concern with the Husky liner is that the sides don't cover up as much of the side by the center console as the WT. Seeing that i paid as much as i did for the WTs new, i might just suck it up and go with the Husky' for my next vehicle.
  • Replies 49
WeatherTech where much better than just the old flat mats when they came out.,
Husky and others followed but improved on the WT shotfalls.
Weathertech is just now mass marketing and has not bothered to improve their mats.
The Husky mats simply fit better and protect the carpets better.
I can't wait for the husky xact liners to get here. I was getting tired of the way the weathertechs fit and just today noticed that I have worn threw some of the coating on them! It's only been 14 months!
Mine have done the same thing in less than a year. I use to have weathertechs in older truck and they were fine..but the ones now are wearing and the edges are folding over badly.... going to try husky next
Well my OCD just got the best of me. I am sick of my door sills looking like someone puked all over it because the WTs flow muddy, melted snow out the door then containing the water. I pulled the trigger on a set of the Husky Contours. Found them on Amazon for $90. Thanks OP for this thread, wasn't planning on spending more $$...
I've used both brands, the techs always seemed too slick to me if it was rain/snowing. Good choice on the huskys! I run the huskys up front and the weathertech in the rear.
Edit* forgot to mention the Huskys are on their 3rd winter and holding strong, carpet looks like new still! This is a pic from this evening.
Sent from my kayak
lol.. Sorry Steve, but you won't regret it..
Got my Husky X-act liners and made a little video.
Those mats do look super nice. Good video [emoji1303]
Excellent video! My son and I both have the Husky X-Act contour liners. I've read a lot of complaints about the Weathertechs on this forum, but your video captures the exact problems with the fit of the WT's in the K2 trucks.
After seeing this video we definitely made the right choice. :thumbs:
Thank you! I liked the extra protection the weathertechs had. I really like the feel of the Husky X-acts more than the weathertechs. If anyone has any ?s or wants more detailed photos comparing them just let me know.
I decided to modify my oem ones to cover up that missing spot under the pedal. I was on the fence about cutting out the door sill pieces and adding them. But in the end, I like having the z71 door sill protected as well. I was also thinking about harvesting some pieces from the rear liner from underneath the front seats, but after thinking more about it, I decided to get my old cargo mat out and cut a piece from it. Not done yet as I have one more piece to glue up the side. But once that's done, I'll paint it black to help it blend in. And then once it all gets dirty, it shouldn't be as noticeable. But in the end, I was more concerned with the carpet protection over the looks in that one corner.
I have 60k and 30 months on my Husky Liners. They were made in the USA and I like the texture of them better, not so plastic, more rubber-ery. They are holding up great. I wear red wing boots almost everyday and I'm not getting heel wear spot I've gotten in other vehicle mats. I got the entire set, front and rear. I know two other guys at the job site with Husky's too and we all love them. I had weather-techs in my F250 and Tacoma... fit nice, but I'm much happier with the Huskys.
My weathertech did the same thing. I emailed weathertech with pictures. They did offer money back.
  • 1 month later...
Anyone know if Husky can be used in with the vinyl flooring? The weathertech says theirs are not recommended for vinyl flooring but I can find if huskys can be or not.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
