2017 sierra denali ultimate
I had the vibration between 70-80 every single time I drove it on my 2015 1500 from day one. I even put a cup of water in the cup holder and had my wife video so I could show the dealer. Took it to the dealer and basically just threw money at it replaced the tires that didn't work then rebalanced them and did a tire rotation stil no luck. We also roared them and finally just gave up and traded it it
  • Replies 36
Great to see a crowd of Denali enthusiasts. I currently own a 17' Sierra Denali Ultimate and am looking for some advice / recommendations for engine upgrades for the 6.2L. My goal is to have increased power, mpg, remove the governed speed limit, and most importantly still maintain my GM warranty. Look forward to hearing some suggestions and thanks in advance.
Well, I'm no expert, but I suppose you could get some moderate gains with bolt-on enhancements like low restriction intake and exhaust (K&N, Borla, etc.) while maintaining your warranty. I believe changing the top speed limit would involve reprogramming the ECM. Doing so could also achieve powerband gains, shift point improvements, fuel consumption changes, and so on. Such services are certainly available in the aftermarket with many reporting positive results, however, reading I've done indicates that GM is cracking down on reprogramming and doing so would void your warranty.
Reprogramming is very obvious for a competent tech to spot and subsystems on current models (engine, transmission, etc.) interact with each other quite extensively. So if for example, you reprogrammed the ECM and later had a problem with your differential: GM could argue that increased power from the new programming subjected the diff to torque that exceeded its specified tolerances, and thus the failure is not covered under warranty. Even if the reprogramming did not cause the failure, it gives them an excuse not to cover the repair, and the things that could break would not be cheap to fix at an owner's expense. Furthermore, it could allow them to void the remaining balance of your warranty period going forward.
I have the 6.2L and considered some tweaking, realizing that there is potential for improvement. I held myself back, concluding that the gains weren't worth the risk. Just about everything I could think of that offered serious improvement would void the warranty. Also, while better would be nice, performance and fuel economy aint that bad from the factory. I think I'm gonna keep it stock, at least for the time being. I might reconsider once the warranty has expired.
Lastly, I believe the top speed limit is justified by the speed rating of the factory-installed tires. You might inquire with your dealer if there is programming available from GM with a higher top speed limit for those that have installed higher speed rated tires. It may be a long shot, but it's worth asking.
Best Of Luck.
I had the GM Borla exhaust and a Cold Air Inductions intake on my 2016. I actually got tired of the exhaust noise and moan from the intake after a year of driving. I think I am going to leave this one bone stock with no changes, On the ECM changes I would only do that after I had 10 or 12,000 miles to make sure that you do not have a problem child engine/transmission, Plus you should be prepared and be able to afford to cover cost if something does happen before the factory warranty coverage is out and they deny coverage. Now on a different subject what is the extra hole in the trim at the bottom of the windshield on drivers side. Looks like where a heads up display could be added easily on these????
Regarding the 'extra hole'
I think you may be referring to the visual warning for the Forward Collision Alert System (if so equipped). It projects a red flashing light onto the windshield when it decides you're about to hit something. I guess you could call it a HUD of sorts, I believe there's a row of red LED's at the base of that hole. Depending on vehicle configuration and system settings, it may be accompanied by an audible warning, an amber indicator at the base of the instrument panel, vibration of the safety seat, disengagement of Cruise Control, brake system preparation for imminent extreme braking, or actual automatic application of the brakes (Forward Automatic Braking).
I love my '17 Ultimate, even with the shaking on the highway. I get compliments on it all the time.
Hey guys,
Any of you here running a leveling kit? I was going to get a lift but I'm going to wait on that till we move next year and I can work something else with the new house. Mean time I need something done it's driving me nuts. Lol.
I'm very pleased with my '17 GMC Denali Ultimate thus far.
The power and gas mileage is quite impressive.
I'm spoiled by the intellibeam headlights and lane keep assist.
I know this will not increase my 0 to 60 time but I think it will greatly increase my enjoyment of the truck. Fold-a-Cover G4 Elite with the recessed tool box just looks like the perfect setup with the TriFold steps with the front section that opens independently and the cool little box in there. I am looking for someone that has one already so I can get some feedback before I order one............ What are you guys using for a bed cover can someone order one and get it on there right quick and come back with a review for how it works with the TriFold steps?.
OK so I guess no one wanted to order one. i just went ahead and got the bed cover (did not get the toolbox yet) looks pretty good so far it appears to be sturdy with nice milled aluminum brackets.
zero vibrations on my 2017 Denali Have 16k miles miles on it and no issues yet. Love the truck.
  • 4 weeks later...
I bought a 2017 1500 Denali 6.2 and have had it in shop 3 times for trying to get them to fix the rough idle of the truck. Last time told me it was a motor mount issue and replaced the motor mounts. I can tell no difference Very dissapointing truck after you spend this kind of money.
M
MarkRo so can you record the rough idle and post it? I think they all have a slightly rough idle and I have driven at least a dozen 6.2's over the last year while shopping. All of them had a slight idle shake. I kind of liked it, reminded me of my ole transam in high school with the cam. You might have something unusual there?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
