Older vs newer?
So I have been thinking. How many of you think the new trucks..2014+ will last or hold up as good as the older ones? I had my 2006 silverado z71 for over 9 years before getting my 2015 z71 sierra. I really feel that my new truck will not hold up or have less problems. I sold my 06 with 108,000 miles and only thing I did to it was front wheel bearing and front pads. Do you guys think the older trucks where built better?
What is giving you that feeling? I feel like my truck is pretty solid. Only thing that is bothering me is the tapping sound from the fuel line. Other than that, if the electrical system stays intact I don't see why these trucks wouldn't last as long as older models.
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
I believe if you take care of them and don't abuse them they are fine.
I had a used 93 Silverado for 20 years, put 200k on it. I did what I call regular maintenance, serpentine belts, brakes, rotors, bearings, tires, batteries, starter, and a trans at 220k.
I do top shelf maintenance due to the fact that I travel mountain roads in rural areas.
My 2012 will get the same maintenance and I have all the confidence in the world that it will serve me well. :happysad:
The only area of concern would likely be the electronics. With that being said I had issues with 8 speed transmission which seem to have been resolved. Want to confirm with a longer drive tomorrow morning. Agree that with proper care and maintenance these trucks should last as long or longer than the GMT900 design.
I guess to me the 06 felt more solid if that makes sense. Plus with all the electronics and AFM stuff Cheap paint,plastic skid plates,just seem they are not built like they use to be. Don't get me wrong I do love my new one. If it holds up as good as my 06 did I will be super happy.
"They don't build them like they use to!" I've heard this reference made about cars and trucks for several decades and I'm sure it was said long before I was old enough to buy trucks. I believe vehicles are lasting longer and are built better.
I hope so..only time will tell.
I remember when the GMT 800's were new, guys swore they weren't made as good as the GMT 400's.
I think these trucks are some of the last "good" half tons before GM follows Ford down the path of junk turbo V6's and aluminum body panels. The K2's are built solid, as long as you change the oil and follow the maintenance schedule, they'll last. I bet the cab corners won't rot away like the GMT 400/800's. And the 6L80 is 10 times better than the 4L60 was and I would assume the 8L90 will be solid once the bugs worked out (if GM doesn't switch over to the 10 speed too soon).
I will admit I turned AFM off right away. I never trusted the system. I also sprayed the underside to keep rust away.
These trucks nowadays are basically computers on wheels. Like with any electronic device, things can happen, but overall they are better built and make our lives easier/safer than the older generations. Just my two cents...
Like others have said, I think the driveline will last. It's the computer gizmos that I worry about.
I recommend frequently checking the oil level. Engines with variable valve timing use oil pressure to control the system, and if you don't keep the oil pan full, you can damage your valve train.
This is my fear too. What happens the day that fancy little computer screen doesn't light up? can I even drive the truck?
I have 100% faith in the engine and drive-train, and i have realistic expectations for rust after several years. but the one thing i have no control over are all those little colored wires running everywhere. When one rubs through or shorts out- kiss $1000 bye-bye.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 501 Guests (See full list)
