Well starting about a month ago when locking the truck the horn "beep" will not work. This is specifically when you park, and hit the lock button twice you normally hear a beep. That beep. Sometimes it does, sometimes it does not work. Even when I hit the lock button repeatedly. Figured it was the remote battery. Bought a new battery and put it in, no help. Then I was on the market for chrome LTZ fobs, bought two off Ebay and had the local dealer program them. Figured that might fix it. Nope, even with the new LTZ remotes it's acting the same. No beep sometimes. So i've tried different remotes, batteries etc. What could be causing something like this?
I had this issue once and found my kids were not shutting their door all the way. I was going to say to check the DIC Options for the horn feedback but if it's intermittent, that's probably not the issue.
Edited by pgamboa
horn works fine. wondering if the horn itself is going bad though, not being very responsive to the short electrical bursts.
Edited by FL335i
I have had this same issue...my kids close the door and I would hit the lock button twice and no horn. So i walked around the truck open and closed all doors, hit the lock button twice more and it would beep at me. Next time when it doesn't beep at you, try going around and opening and closing all the doors again. In my crew cab, it is usually the back door on the drivers side, for some reason that door does not close very good.
I know the rear doors take some effort to close... I'm wondering if maybe a position switch is out of adjustment. Good places to start!
  • 3 years later...
I have the same exact issue happening on my ‘14 Silverado LTZ. Did you ever figure out the issue; and if so, what was the fix? I’ve had it looked at the dealership and they had no idea. Just threw a new horn at it in hopes it would fix it. It didn’t work.
My 14 Sierra SLE seems to do this sometimes.... Hope it not a computer issue or something big on the horizon.
Will check doors next time
22R
  • 2 years later...
22R
Any luck on determining what is causing this issue? My 2014 recently started doing the same thing. Thanks.
Still does it but has not created any sort of issue either.
Yotaman
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
