I have finally gotten around to installing the DQS tow mirrors on my 2016 Ltz 2500 6.0 gasoline truck. After hours of trial and error of trying to figure out exactly where the wires go, I have completed the modification. Only to find out that sometime during the installation, I must have touched the wrong wires together and now my driver side tail light and driver side front marker/parking light are out. All other lights are working as well as power fold. It got dark on me but I’m thinking it may be a fuse. Anyone else encounter this or have any suggestions on where to check in the morning for the cause? Fuse number, etc.?
Just the driver side?
43 minutes ago, HunterC10 said:
Yes, only the driver side.
Check Fuse #29.  F29UA.  This fuse in the Under Hood Fuse Block X50A.  The Driver Side Fuse Block under the hood.  Shows to be the Left Park Lamp Circuit.
Thank you sir. I will try this in the morning and let you know what I find.
This fuse was in fact the culprit. Thank you again, pgamboa, for I was only able to do this mod with your help via videos/pictures in conjunction with some of my own research, plus another guy on youtube. I would suggest to anyone else wanting this mod to purchase the plug n play harnesses from you as soon as they order their mirrors! I was able to use the extra wiring and “pins” that came with the aftermarket mirrors after dismantling their connectors but it was a little time consuming.
Glad to hear and thanks for the feedback!
Hi there.  I have a 2011 Chevy 2500 ltz crew cab diesel.  I have those Lil car mirrors which have power, turn signal, memory, driver dim and powerfold.   I want to update to the 2015 style tow mirrors.  But I can not for life of me find ones that offer the powerfold option for my year!!!  Where or what i can donto get the tow mirrors with all my options especially the powerfold???
I only have info for 2014-2018. Sorry bud.
Doesn’t the chevy body style go from 2007-2014 years.   Would the 2014 mirrors work?
Check these out. PART #: 1AMRP01811 from 1Aauto. Doesn’t look like they’ll have driver dim though.
Sweet deal there thank you.   Love to get the model with the led spot lights on the mirror( new style tow mirror).
Wanted to order the tow mirrors  harness for my 2015 Silverado 1500 later edition with WiFi
Please send me a PM for ordering instructions.
Thanks!
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
