Just wanted to send a big thank you to Phil for providing the community with his resources. I purchased a set of Syppo tow mirrors for my 2017 Sierra SLE, and Phil's DIY kit. Shipping from Phil was fast, instructions were straight forward. I started with the passenger side, took me about an hour or so from start to finish, then about 15 minutes on the driver's side. With his DIY kit, each door harness is required to be removed, then Phil's kit wired in and pinned in the door & mirror connection. I also installed the diodes for the bcm mod, that took about 30 seconds. Phil was quick to reply to a couple text messages I sent throughout the process to confirm the direction was going. I would not hesitate to work with him again in the future.
Edited by Scottyz71
Spelling error
Pgamboa,
PM Sent sir. Tons of great info here.  Thank you!
Edited by Slapps74
@pgamboa I want to upgrade my standard mirrors to the tow mirrors. I have an LTZ 1500. It has all the options for the mirrors, puddle lamps, power fold , memory, Dimming etc. I have only read through some of your stuff, so I'm not sure what all your kit will control. Will your kit control everything that the LTZ 1500 has?
Need to know your year to understand the upgrade path.
@pgamboa it is a 2015
Ok. I’ll need you to verify your door jamb connector and see if you have pins 9 and 11 on the cabin side of the connector. These are the cargo light and running light circuits.
On all 2014 and some early 2015 trucks, these circuits are missing. For mid year 2015, they are present.
So let’s start there.
@pgamboa Ok, I will check that out and let you know. Also , do you know if these mirrrors have to be the GM mirrors for your kit?
Edited by Donny Fowler
Does not have to be GM mirrors but has to have the correct pinning of the wires in the mirror harness.
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
I build harnesses for any tow mirror. :). As long as the maker follows the factory wiring pinout.
@pgamboa I saw in a previous post that you can get the tow mirrors a little cheaper than what I've found. I have a midnight edition and want the black mirrors. How much can you get the black mirrors for?
Send me a PM.
On 7/3/2018 at 9:45 PM, pewterliftedz said:
I went with the AM auto with chrome caps that have every function, including power fold and memory.
i only paid $399 for mine since they were on sale for $499 and  I had a 20% off eBay coupon.
Do the plugs on these mirrors plug into the harness in the door? Also what are the three wires with barrel connectors for?
Yes and no. The main 18-Pin Plug will... but the 3 wires... 2 of them are landed into the connector But the 3rd doesn’t. The 3rd wire is a running Lamp wire and it is presumed that
You are hardwiring this along with any new lighting features you don’t have.
With my harnesses, I correct all that and provide the pigtails needed so that you don’t have to Hardwire it.
I recently bought a 2015 2500HD with the DPN tow mirrors on it. I know this is going to sound backwards, but I actually want to put a standard size mirror on it. What all would I need to do as far as wiring to swap my DPN mirrors for a DL3 mirror? Any help would be greatly appreciated. Thanks!
Edited by fastls199
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
