Floor Liners gm 84073613 & gm 23237403
I'd like to see the GM / husky / wt compared side by side
guys FYI there is a very good thread showing OEM floor liners, however not sure about them side by side, someone would need to own both sets.
http://www.gm-trucks.com/forums/topic/184854-new-gmc-floor-mats-2016-these-are-real-nice/page-5?hl=floorliners
OP I am very satisfied with the GM floor liners, fitment is top notch, they are very thick robust liners. I have no issues with the driver cutout on the gas pedal
That thread shows off the GM ones well!
They are nice looking but the hole in the front mat and the seam on the back mat are horrible decisions by GM.
I work in winter road maintenance and I know for sure getting in and out of the truck with snowy / salty boots will ruin the truck with the big gaping hole under the accelerator pedal. :(
I enjoy the added door sill protection from the GM ones. Although I agree that the under pedal protection is lacking from them. So I modified mine and added an extra piece under the pedal to cover that area. Works like a charm now.
Well I don't have pics of the others, but maybe someone else will. I snapped some pics of my husky liners for you guys today. They're dirty, but their just doing their job, haha.
Driver's side
Passenger side
Rear with seat down
Rear with seat up
  • 3 years later...
Does GM offer a mat that covers under the throttle not Weathertech or Husky and what's the part # if so? I can't find them checked every dealer and they said they don't make them but I'm sure I seen they do on here but can't find it. 2017 High Country
GM does not offer a mat that covers under the gas pedal for these trucks.  I have/had GM ones for Terrain, acadia and enclave and they all covered under the gas pedal. And I do like their quality/feel the best, but I wanted coverage under the gas pedal.
I have had husky and WT in previous vehicles. between the 2, I prefer Husky as I felt like the WT were more rigid and would curl up more on the edge.
For our 2 K2 trucks, I actually took a chance and bought a set of oEdRo mats off amazon (front and rear for double cab) for under $100 for the set and feel like they are just as good as the Husky's.
I thought so, one dealer told me they do and another don't, so I just wanted to be sure. I have two sets from GM that dealer gave under warranty brand new and a front set to fit 2020 that cover under the gas pedal again dealer gave but dont fit. Guess I'll  be selling 3 sets of mats lol. Thank you
ah dang, well if I was given a gm set for free... I might have kept it! I just didn't want to spend money on a set that didn't cover where most of the salt and sand falls in the winter time.
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
