The plugs are not the same!! The 1500s seem to be a bit smaller. Still you can use the dummy plug provided that you have the hardware to swap plugs. Can anyone provide a pic or a pin out of their 1500 bed light plug for me so I can make this dream come true. Just got the harness for the 2500 and all thats dufferent is the plug size. I have the pins to swap plugs just need the correct pin out.
Anyone has the part number for the harness for a 2016 ? I looked up this part number and it says it won't work on a 2016
part #22878806
part #22878806
That part is for the 2500s which is an 8 pin connector. The 1500s use a 6 pin connector. I have yet to find only the harness for 1500s for sale. Cheapest kit I've seen so far was for $99. You can use the dummy plug and make your own harness which is the cheapest way to go. A few posts here will tell you what components you need. As far as I know, there is no "only" harness yet.
  • 2 years later...
I mounted NiLight 3 piece LED strip lights under the bed rails and spliced into the cargo light switch/wires that powers the stock LED box lights in the bed. When I turn on the cargo light switch the LED strip lights and stock LED box lights flash 3 times and then turn off. No fuses popped and the cargo lights stayed on the entire time. I tried putting in a bigger fuse and still the same result. I also test the strip lights before install and they worked great, no flashing. My goal is to have the cargo lights, box lights and strip lights all be controlled by the cargo light switch on the dash AND have a switch in the bed. Not sure if that is even possible. Any ideas what is causing the lights to flash? Can I solve the flashing problem and have the lights controlled by 2 different switched with a diode or adding a relay?
2019 Silverado, LTZ
Any help you could send my way would be greatly appreciated. Thank you
2019 Silverado, LTZ
Check this thread out, it's basically what you want to do. I did this and really like it.
https://r.tapatalk.com/shareLink/topic?url=https://www.gm-trucks.com/forums/topic/225685-add-bed-light-switch-to-truck-bed/&share_tid=225685&share_fid=33003&share_type=t&link_source=app
These are the strips I bought and posted pictures of the light output.
https://www.amazon.com/dp/B01JUE9OLM/ref=cm_sw_r_cp_apa_fabc_0W5Y25FG3MCFN6JERZPT?_encoding=UTF8&psc=1
Sent from my SM-N986U1 using Tapatalk
New guy here but I followed the above thread and it worked well.  I did solder in a diode according to another thread on this forum just in case.
My truck has the Cargo w/ Reverse Diode mod done, but I'm going to add a proxy switch at the tailgate to keep the bed lights from coming on while in Reverse.
  • 6 months later...
Hi all, I am looking for the OEM wire harness for a 2016 LT 2500 Silverado to allow me to add bed lights that run off the cargo switch in the cab. The best I could find was GM 23327843, so I ordered it and entered my VIN and got an email stating that part would not fit my vehicle.
Can anyone weigh in on this?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
