Got the terminals to release.
Verified the terminal
...and discovered that I should have ordered the thinner TXL 18ga instead of the GXL type. These connectors have tight tolerances.
What's it's part number?
15127038 ordered from GMPartsGiant. Listed as the Service Connector on Upfitter.
Interesting because the Upfitter disclosed that terminal part #...
I have observed that the terminals are built the same (the front portion with the tangs) and the difference is the crimp part. I found that the crimp tool is also important in the pitch used and an incorrectly crimped connector will result in a very difficult insertion.
I learned this the hard way in my Mirror Harness DIY Kit I sell. Played around with different size terminals for different side gauge wire... which meant different crimp tool settings.
BTW - I look at ALL 334 possible connectors on Mouser's site with the filters - "8 Position" and "connectors". There were a couple "close" ones - including the one you bought. No cigar. Guess there isn't an alternate manufacture aside from Yazaki and the GM - AC Delco one you purchased with the pre-terminated leads on them. Sorry sir.
Edited by pgamboa
Wow, thanks for doing that. At least there I can get the pigtail.
I wasn't clear. Sorry about that. The connector specified in the upfitter manual fits perfect. It matches what's in there. The wire I ordered has too thick of an insulation jacket. Did some research and found where GM uses TXL type automotive wire, which has a thinner jacket. GXL is thicker and used more in high heat environments. There's not enough tolerance in the connector for the GXL wire.
Ah understood. I use Remington 22AWG Stranded wire and has been a good choice. 24AWG was too thin to properly crimp, and 20AWG was too thick on the insulation.
I'd be curious on your source for GM Color Coded Wiring. That would be awesome if I can implement that and be one step closer to "Factory"
I've been using 18AWG. However, these connectors have tight tolerances. The TXL type of wire should be thin enough. We'll see when it comes in. If not, I'll look at 20-22AWG.
I'll link to the eBay seller when I get in front of a computer.
Edited by cmatt
Before its all over somebody is going to transplant the entire dash out of a Yukon LOL. Hopefully this doesnt turn out like that $5k factory brake controller upgrade they where talking about earlier.
Although that would be cool, at the most, it shouldn't cost more than $1300.
Sent from my SM-G935V using Tapatalk
Got the Denali cluster and HUD installed today. Thanks for the programming Chris! Pretty amazing that he can make options work that GM won't.
Also put the HUD in, but it doesn't work.
EDIT: I'm an idiot, sort of. Let me say it would be wise to read up on how to operate the HUD unit before jumping to conclusions. Especially turning it on. GM uses the brightness control to turn off the display. I think my issue was that, the display was positioned all the way up and the fact my OE defroster panel was covering the top half of the display.
I know it's not pretty, but here's the harness. I'll make a proper one when I get the smaller wire.
I used one of the grounds the I/P harness uses. You can see the threaded stud and nut just to the left of the speaker.
Added the wire to the cluster harness.
Here's a closeup of the terminals the cluster connector uses.
The yellow dimmer wire from the HUD switch goes to the X2 connector that's located on the backside of the left I/P fuse block.
The red/gray stripe power wire also goes to the same X2 connector.
Here's where the HUD sits.
There's a metal tab just under the plastic tab that needs a j-nut and bolt to secure it. I'll have to grab that from the dealer.
I had to remove about 1/4" of the plastic on the right side so the USB cable off the cluster would fit.
You can see the different shade of the Denali aluminum trim compared to what's on the steering wheel.
The visor wouldn't fit. The opening in the defroster panel is too far left. I'll have to see if the Denali one has a different part number.
Edited by cmatt
So the defroster panels are in fact different. The Yukon Denali one has a wider opening and is positioned just slightly more to the center of the dash compared to the original one in my Yukon SLT. That fits the HUD display perfectly.
You can see how the cluster visor with the HUD cutout now fits.
The correct one is on the left. My original on the right.
I think the HUD unit is supposed to sit up flush to the dash trim. I'll have to figure out how to raise it up and support it.
I think that's what's causing it to have the ghost image.
Edited by cmatt
Did the HUD use the same screw holes as the collision detection piece?
What was wrong with it before?
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
