Help needed.
skully85
So, took my 2017 Sierra To the local exhaust shop told them I wanted something that sounds good but nothing loud. So we agreed on basically a flow master muffler with duel exhaust. $400 out the door. Seemed fine, got the truck back and it sounds great to me. The wife on the other hand absolutely does not like it. Considering she bought the truck for me, I have "thought" about going back and just redoing everything to a single pipe.
My question is how much of a difference will that make??
A lot of guys with picky wives swear by the borla touring. It's just as quiet as stock until you put your foot all the way in. hope this helps!
Skully I assume they put on a 40 Series 430402 one inlet dual outlet muffler with 2.5 inch tailpipes. Case length of that muffler is 14 IIRC and it sounds aggressive and droans considerably. You are going to want them to replace muffler with Borla Pro XS 40349, Magnaflow 12288 or the larger 12588, or Dynomax Super Turbo 17776. These mufflers have longer cases and will be noticeably quieter than the 40 series Dronemaster.
I'm running the Magnaflow referenced below (part #12288). I love it - has a really nice rumble at the cold start and sounds great when you get on it. On the highway cruising at 65-70 mph, sounds just a volume notch above stock, practically imperceptible. HOWEVER, I do have the AFM turned off. With AFM, the drone at 45-55 mph was pretty bad and I just generally disliked the V4 note. With the AFM off, I have the exact sounds I was hoping for. For the record, no wife here to please but I do have 2 kids. My 14 year old son can tell the difference at startup and hard acceleration, my daughter doesn't see any difference. They complained significantly when I had my Durango, which was, admittedly, pretty loud. If you're curious about that beast take a listen!
That being said, could I just swap the mufflers out or am I going to have to do a whole new system??
Try dynamat on the rear wall, floor and doors. Made a big difference in my truck and I've only done the back wall and rear floor as of now
Take her ride when you go out together. My wife put up with loud mufflers for 20 years. Then she got a Z28, problem solved. Going on 43 years now.
Yes, you should be able to swap out the muffler.
Just swap mufflers should be good.
So just got back from taking the wife and little tot to get some ice cream. I noticed something and maybe someone can help me out with it. So for example at 50mph my truck goes for v8 to v4 and there is a terrible drone like sound. Anyone ever heard of this or had this issue??
Everyone who's put an exhaust on one of these trucks. You can either turn off AFM, or spend the money on an exhaust that won't drone such as Corsa, or leave the flapper valve intact.
Skully any exhaust will do the "V4 chop" but Flowmaster is more noticeable than the others. Go back to the shop and have them swap mufflers. If you are like me and afraid to lose warranty than drive in M7 or M5 to 60 or so. My V4 chop is hardly noticeable even when in regular drive but then I do have the factory resonator still on truck.
    • 3.41 Kroger’s in Montgomery TX
    • I really wanted to go to the Fox 2.5's But they were like ~$1,500 vs ~$425 for the Bilsteins. And my research on FOX shocks was that they do not have a great reputation for longevity. I am sure they the FOX's are fantastic, but I know from experience the Bilsteins are rock solid for at least 150k miles.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
