bilstein shocks 5100 confusion
I was thinking of ordering some to drop in but found conflicting post. So do you need coil spring compression tool for the front? or any special tool at all. I saw a few post saying yes and other post saying no and I think I saw a video that showed nothing special needed.
And what ring placement position is most likely to level the front out ? I am sure i can find this answer if i search a bit more
2014 SLT z71
Are you lifting on lowering. And is this for the front?
Set on max height almost lvls. Spring compressor tool used on front. Theres a way to do it with a jack but I'm not sure how or how safe it is. Rear takes 21mm socket/wrench and less that 20 minsa7e14b61fec3da9d5c167427617ef8f8.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
It can be done without compressing the spring but is too dangerous IMHO. To do it right, remove the assembly and hand them to a suspension shop with about $40 and your new shocks. While you chug a beer in the lobby they will compress the springs and install the new shocks. They will hand the assemble right back to you ready to install.
I wouldn't recommend using a standard AutoZone special to compress these... My buddies wall mount compressor was scary enough to get the 5100s built at the highest lift position
Sent from my SM-G930V using Tapatalk
i've done it on cars by putting jack under control arm, unbolting the shock/spring assembly, put a pillow to absorb any pressure from the shock/spring assembly, lower jack slowly and pray lol. probably not the safest but it worked.
ok sounds like a shop needs to do the front i am handy and have tools but honestly coil springs scare me.
so looks like adjusted to the max will level the truck? for some reason i thought it was middle setting
oh yea thanks for the responses
Am I reading this correctly that you jack the truck up, place on stands, use the jack under the lower control arm to relieve tension, then remove the bolts on the top and two on the bottom and pull the entire assembly out ? Take assembly to swap out shocks and then reinstall? Im tired of level kit of how bouncy the truck is.
You got it.
Is it worth doing all four corners ? Do the backs make that much difference? Never tow with the truck and never really have any super heavy loads in the bed.
Won't you need an alignment on the front after putting in the 5100s at a higher level? If so, just go to a shop that does both and be done with it. Do the backs yourself.
Yes alignment will be needed. Do all four corners!
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
