8-Speed and Blackbear Tuning Impressions?
Any update on this?
Sent from my SAMSUNG-SM-G920A using Tapatalk
This is what I got back from BB. Haven't decided what I want to do yet.
Hi Paul,
You are having to use less throttle for the same rate of acceleration, which is resulting in an earlier upshift. We can dial back the response at light throttle a bit for you to help that out if you would like. There is no transmission tuning available on that model, you are still running the OEM shift points as a result.
Justin
Hi Paul,
Justin
I know that bringing a tuned truck to a dealer might not be the best idea but could a transmission service fast learn procedure possibly help? I know they are supposed to do this after any new updates are added to the tcm programming.
Sounds like you need to drive it more!! Like DRIVE It haha. In all seriousness tho that just sounds like you need to hold off till they figure out the tuning with that transmission
  • 11 months later...
Hi Paul,
Justin
How did it go?  I was wondering if I had enough time to get the tuner and files for a road trip (towing) in two weeks.
A 2017 with a 6.2L and 8-speed can TECHNICALLY have the TCM tuned without using HPTuners. This is done by swapping your current TCM with an older one. You can get a 2015-2016 TCM and Black Bear will tune it for you. I don't think they have any TCMs left to buy though, so you gotta find one on your own. Here's some info from a post I made in another thread.
http://www.gm-trucks.com/forums/topic/157013-what-have-you-done-to-your-k2-today/?do=findComment&comment=2105247
I just had my 18 6.2 at the dealership for a TCM program update it was for improved shifting, they did not do a " fast learn " on the trans. I don't know if they are supposed to that after a reprogram or not. I'd like to find something that says they should. A fast learn only corrects clutch fill times I don't believe it has anything to do with shift points or tq converter lock up.
Actually I just read one of the bulletins, and it does say that if a TCM is reprogrammed, a service fast learn is required. So I'm going to call them tomorrow and see what they say.
I just thought of something and perhaps Justin will chime in, think about this, is the fast learn something that needs done? When someone tunes there truck through any of the tunners. We don't do a service fast learn from the dealer. I know the don't tune the 17+ 8sps but some of them have tuned the 14-16 8spds and I don't think they tell you to take it back to the dealer for a service fast learn. Just something I thought about.
Took the truck back in to the dealership to have the transmission service fast learn completed after having the updated TCM calibration for improved shifting. I can say for a fact that the truck drives and shifts better after having the service fast learn done. They were infact to do the fast learn after doing the updated TCM calibration it didn't get done on Friday , but they did it for me this morning while I waited. I'm glad I took it back to have it done. Also before I took it in this morning , I looked to see if there were any ecm calibration updates. They were two showing that may be available. They hooked it up and they were so they updated the ecm calibrations as well. My fuel mileage is back to where it was prior to the TCM calibration. So either the fast learn or the ecm calibrations or a combination of the two have deffentaly made a difference in how the truck preforms. I recommend anyone to check in TIS WEB or with there dealer to see if any updates may be available. They don't cost anything if you are still under warranty. And if you are not i feel it's still beneficial for the shop rate which should only be a one hr charge at the most.
Thank you Justin for providing the information and link to check out. I wasn't aware this was available.
Anyone know how to do this?
For the service fast learn it needs to be done at the dealership on there gds2. I believe that's what gm calls there system now. There are however individual clutch learn process that can be done on your own . The process varys from certain years. It's a pretty lengthy process of varying driving conditions , gear selections, rpms and mph. I don't have a link for it but Google 8l90 flast learn or clutch learn and you should find some information.
  • 9 months later...
Bringing this back. I have a 2018 5.3L 8 speed. Has anybody else had any experiences being that we can only tune the engine in these? I’m actually not too bummed out on the shifting, I just want a nice predictable feel in the throttle with a little extra get up and not so much lag.
  • 1 month later...
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 445 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
