Softer shocks?
I see a lot of people like the 5100's, but say they are firm.
I can basically perfectly imagine what they are like. You get a lot more road feedback because they are firmer, but they absorb potholes like a vehicle should and not make it feel like someone just hit your dash with a sledgehammer. That's great and all but what if I want a more luxurious ride that I don't feel the road or the potholes.
I don't tow a lot of weight and I don't have heavy loads in the bed. I came from a tahoe and the suspension was a better fit for me.
So is there any sort of shock options for those that don't mind lowering their towing and hauling weight capabilities?
Don't get me wrong I still want it to have some capability, but I would be absolutely fine with a max tow rating of 7k lbs instead of 11k lbs if that's what it took to have a better ride.
Help us help you. Tell us your tire size, drive train and suspension options.
When on the correct setting, I would not call 5100's firm. Now jack up the front rings and it is a different story.
Unless you have them maxed out on the top lift setting where the spring is pre-loaded. They do ride better in many instances and harsher in others. Either way they aren't a luxury riding shock the OP wants (I have no idea why it is a truck but besides the point).
You want a softer ride, you have to go with a desert running shock like from King, Fox or Icon and change the springs as well (the springs are a big component of the harsher ride because of the added capability they provide.
Best bet IMO, find a nice luxury SUV and a travel trailer if you need a bed once or twice a year. It will have more features, ride better and be better on gas as well.
Tyler
Tyler
while you do have a good point, i believe hearing that the rancho shocks that GM uses are crap, harsh ride and don't last long. if the OP has those shocks, then i can see him getting a better ride with something else. aftermarket springs might help too, though i don't think there are any aftermarket springs for this truck...
Anyone run the adjustable Rancho 9000XL shocks and have feedback to offer? Putting them on a soft or softest setting may be ride OP is looking for.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
