Oddly enough, I already have a couple of those from the exact same vendor! Mine are currently in the back. My kids are still in booster seats, and the extenders make it much easier for them to get buckled. As luck would have it, my daughter just crossed the age where she no longer needs the booster, so I may be able to relocate the extender. Great idea. Hadn't even thought about that.
Has anyone fiddled with the chime module itself (or is it even reachable without major dashboard teardown)? I'm still thinking about a good foam wrap. Also wondered if a resistor could be spliced into one of the feed lines. The mechanical engineer in me refuses to give up. :)
You can get the extenders for free from the dealership, I got two for when I am hunting and don't need a seatbelt.
I hadn't noticed how loud it is until after I had a sound system upgrade done, I wasn't able to find any settings on the touchscreen or on the MID. It sounds like I'll need to have a dealer do this...Thanks to all for the info.
You can also go to a salvage yard and cut out a buckle for free. At least they only chime twice, unlike Ford trying to force you to live your life by their rules.
Took my vehicle in for servicing and mentioned the ear ringing chime volume and that I thought there was a TSB to remedy it. They looked at me like I was nuts. But said they would check on it.
They found nothing and it still rings my ears when it goes off. Annoying as hell.
The Bulletin #PIT5328b was written on my work order. I hope this helps. The improvement for me was significant.
The chime module is built into the radio from my understanding. The turn signal is also generated here as well. This is why the noises come from the speakers. Short of replacing the radio or messing with the speakers, the dealer service mentioned above is the only way I know to adjust it. Breaking the chime also breaks the signal noise.
That's the exact one that is on my work order. But for the me the change was noticeable but not low enough.
Had the truck in for 1 of my free oil/tire visits today and asked about the chime volume. Like Hawkeye mentioned above, I got a "deer in the headlights" stare from the shop's supposed electrical guru. Kicking myself as I hadn't been back on this thread for a while and Donstar referenced an actual TSB. Grrr.
Will take that with me next time I go back as I didn't have time today for them to research from scratch. I've ticked off many a person on the other end of my Bluetooth phone connection as the speaker sits right below the microphone. It's bad enough in the cab, but they say it's earsplitting on the other end.
I've played with the radio's chime volume setting some more, but it honestly appears to do NOTHING at all in either direction. Same thing for automatic mirror fold (or something like that). Can't figure out what it does when enabled. For what it's worth, the reverse mirror tilt setting does work, but I don't like it. Too disorienting for me when trying to back with mirrors. Just my luck. The 2 settings I want to work, don't. And the 1 setting I don't care anything about, does. *sigh*
On my 2017 - you can power fold the mirrors by pressing and holding the key fob un-lock button. And/or you can set it up for all four windows down at once. I have it set for just the windows - for hot days when approaching the locked rig...........
Krusty is correct for "automatic folding mirrors". First you need to enable it in the settings menu. Then when you hold the key fob button it will fold your mirrors. So it's not really "automatic" ...
Edited by sk
Me Too - still VERY loud
Prior to this service, the chime hurt my ears and passengers complained or at least commented. It is now no more annoying than my previous trucks or my wife's Toyota. Passenger comments ceased the day this was addressed. I will check with my dealer to see if they did anything special other than what was stated in the "TSB". I know that the chime volume control on the DIC does nothing and am wondering if less informed dealers are using this control thinking this is all that can be done. I doubt this chime issue was present on all years and models so it is a flaw that can be fixed.
They had to download a new (?) that took 40 minutes +- and it reset everything back to factory settings, even the trans had to relearn, it did lower the volume but - as you said - still loud like my 2011 25 HD was ...
  • 2 years later...
I know this is an old topic, but I recently ran across this and had trouble with it myself. I have a 2015 Tahoe LT with the HMI 2.5 module that has CarPlay/AndroidAuto.
For me, setting chime on the *lowest* value did not work. I had to set it on the “2” in order to get a very low (normal) door chime.
Ignition must be in on/accessory to access the Vehicle radio option.  I’ve attached some pics to show how I accessed it and what my current settings are.  Anything lower results in a very loud chime, which kind of goes against how +/- works, but ??‍♂️
    ncleg
    ncleg
  • Who's Online   3 Members, 0 Anonymous, 1,235 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
