Have S8+ with a case did this quick and easy just flip the rubber part and you're good to go
This!
Edited by wingsaa
this.. Notes: 1) If phone does not charge, remove it from charger for 3 seconds and rotate phone 180 degrees.
I have the S7 with a thin case, and 2016 - mine charges 70% of the time (first try) if I use this method.
Edited by GMC-AT
I had the wireless charging in my truck i installed myself but didn't like it, so I just went on eBay ordered the fast wireless charging USB plug and it so better and faster
Has anyone made this work on their iPhones? I know there are some external coils you can stick on but not sure how well they work
I'd wait for the new iPhone 8 or whatever they are gonna call it, it will have in built in wireless charger
It will likely be proprietary, so it's doubtful it'll work with the chargers in the trucks.
Sent from my SM-G920V using Tapatalk
It should work with the trucks, from my understanding iPhone will be using the same wireless technology as Samsung, QI compatible tech stuff lol
Why would it not work with the truck?
I've got a Iphone 7 but have a mophie case on mine that handles wireless charging. The truck charger works great with it. I've enjoyed not having to deal with wires.
For the same reason an iPhone can't use the same usb cord as practically every other phone, haha.
But apparently, I was wrong. If Apple's unit is Qi it will work. Granted, the factory installed chargers seem to work less than stellar with their one coil.
I have a S7, and it charges fine in my truck....
...because I installed my own 3-coil wireless charger under the mat. :)
How did you do that?
Does anyone have an iPhone 8 with the wireless charging.  Does it work? Thanks,
Yes, works just fine. I’ve tried it in a silverado and a traverse.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 1 Anonymous, 688 Guests (See full list)
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
