Will the Rev2 harness work on the GMC Canyon/ Chevy Colorado with the 4 wire connection?
It will not.
On 3/7/2018 at 10:14 AM, pgamboa said:
Holy moly! It’s gotta be the extra ridge. LOL. Let us know.
How do I know if my 2018 Sierra SLT has the newer mat?
My iPhone 6s Plus doesn’t even fit in the space or support wireless charging. I am due for an upgrade though...
Count the # of ridges on your mat. If you count 10, you should have the newer module. You can also remove the cover under the lid.. but I fairly certain a that all 2018s have the newer module. But it’s GM.. so would verify it for myself.
I count 10 or 11 depending on where you start lol. Build date 12/2017.
Looks like the 2018 mat. You should have the 2018 module that we are all upgrading to.
Just installed the 2018 module and rev2 cord (Thanks Phil!!). Took about 20 minutes and watching the video from Phil before made it super easy.
This was installed on a 2017 Chevy Tahoe and my phone is an iPhone X. Works perfectly
@pgamboa I should have bought one of your harnesses.  I was trying to repin the connector and broke one of the electrical pins.  Could you tell me what you purchased to replace one of the pins? Thanks.
[mention=159655]pgamboa[/mention] I should have bought one of your harnesses.  I was trying to repin the connector and broke one of the electrical pins.  Could you tell me what you purchased to replace one of the pins? Thanks.
Sorry to hear. These pins are very fragile. Without the right crimp tools or extraction tools, this can easily happen.
Send me a PM and will help ya out.
  • 5 weeks later...
My turn.......have a 2015 GMC Sierra Denali 2500 HD without wireless charging.....yet
#1 - Will I find a harness in my console or will I splice into the cig lighter for power?
#2 - If I purchase the 2018 charging module... will it mount under my center console lid or do I need a Wireless Charging Console Mount PN (P)012001866AA?
Edited by Sirshopolot
add vergage
If your truck came with the factory full center console, it will most likely not have the provisions on the mating side of the connector up front. So even with swapping the center console harness itself may not work. You’re probably better off splicing the the rear cigarette lighter plug.
Not sure on this either. I highly doubt a non-wireless charging lid will have the provisions for the mount. I wonder what would be involved with retrofitting a mount.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,109 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
