On my 2018 the charging is hit or miss for my Samsung S8. Will this update kit help my 2018 or does it already have it?
Your 18 should already have the updated software and hardware to allow the newer generation wireless charging.
This kit is basically the 2018 stuff, with an adapter to put it in earlier model trucks.
Sent from my SM-G955U using Tapatalk
It might be an issue with your phone. I have an S8 plus, my wife has an S8. I only changed my rubber tray out for the one that your truck comes with and neither of us have issues. My plus is too big with a case to fit in the tray, so I just pull it off when I want to use the wireless charger.
Thanks for the replys. Could be any issue with my phone. It works on my wireless charger at home. It does charge but it comes and goes.
For me, our S8's need to be pushed as far towards the back seat, as the tray will allow. If I drive down a steep hill, or stop quickly, the phone slides forward a little, and stops charging. You have to wait 3 to 5 seconds before putting it back on the charger. Make sure that's not your issue. Whenever I'm stopping, I rest my hand or elbow on the front of the tray so my phone can't move.
Thanks for the tip. I have always had the phone always slid to the very front of the charger. I'll give it a shot keeping it all the way to the real.
A gripe that I have with this too! I have my audio rocking when I’m driving. So much that the phone is always forward.
Like other members said we upgraded to what you have in your truck. What you could do is take the top of your center console off and flip the rubber tray were the phone rests while charging. What that will do is put the phone all the way back over the actual charger. That's what I did with mine and my S8 stays charging anywhere it sits even with a case on it.
Edited by Da1daonlySully
I'm going to try to come up with something that can sit in the tray with the phone. Something to keep it in place
It seems that the 1st gen rubber mat, when rotated 180° may be enough of a stop :). Problem is, is that I replaced with the later model mat. [emoji23]
It seems that the 1st gen rubber mat, when rotated 180° may be enough of a stop [emoji4]. Problem is, is that I replaced with the later model mat. [emoji23]
I'm not sure, there might be either too much space or not enough? If the part with the sticker was smaller, that lip might hold the phone in place? Otherwise, is that space enough to cause the charger to stop working?1d145183783b43d0cfce1e0fb8c20405.jpg
Has anyone tried charging a "phablet" sized phone like the iphone 8 plus?  GM's website says it won't fit/charge.  Curious to know if anyone has tried or has any solutions/trays/mats that would fit.  Thanks!
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,335 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
