8 hours ago, mn camper guy said:
What does this kit provide for you over what is in the truck already? Or is this kit only for those that don't have wireless charging in their truck?
I have a 2017 Sierra, would this fix my pixel3 charging issue?
You likely need what P/N is for the 2018 module.
That said - why bother?  You can't do wireless Android Auto.  Just plug your phone in and be done with it.
Sent from my Pixel 3 using Tapatalk
My 2017 factory wireless charger would not charge my iphone 8 plus, so I upgraded to the 2018 updated unit for $65 which does charge my phone now.  And yes it would most likely solve your wireless charging issue.
Now that I have 2 chargers I can have my phone connected to apple car play, and my wife can still charge her phone on the wireless pad.
Edited by pewterliftedz
My 2017 Yukon Denali is doing the same thing; it will not charge my iPhone 7 or X. Charging bolt comes on for a couple of seconds then goes off.
There are a couple of ways to do this from what I have found; swap out the module to an 18' (part number 13521066) and modify the 3-wire connection from your 17' to it, purchase a retrofit kit from Infotainment that has the connection extension already modified with the module for you, OR (and I have yet to confirm this) purchase an entirely new Center Console Armrest Assembly from GM that includes the new module and wire connection to your vehicle.
Has anyone here purchased an entire new Center Console Armrest Assembly (GM Part#84329326)  and just swapped them out to get the wireless charger to work in your 2016-2017?
  • 3 weeks later...
On 2/1/2018 at 8:38 PM, ThunderBunny01 said:
Big shoot out to pgamboa and his video.  I was going crazy as to why my iPhone X would not charge in my 2016. I just got my 2018 module and ordered the new conncector.  Took about 15 minutes to put everything together and pin the new connector, now everything works like a charm.  I did not rotate my mat, and i can charge as long as the phone is touching the back stop.
I do have a 2016 module for sale...if anyone wants a nice paperweight. LOL
This is great info, thank you! Any chance you have the link to his video and the part number to order?
I stock the module kit as well. PM me so we can go over the validation.
im have issues with charging iphone  Xr when plugged into car play port CC'17....anyone else with this issue?
  • 4 months later...
@pgamboa I have the 2017 Chevy Tahoe.  Would the module switch with the 2018 GM part work to upgrade/make compatible my charging pad with my iPhone X?  If so can you send me info on your cord where I won’t have to change those pin things and also can you send me the info on where to order the new module.  I did hear in your video that it was on back order...hopefully not now though!  My email is ukpa09 at gmail.com -thanks a bunch!!!! And by the way- I’m in medicine and am not mechanically inclined- thank you for breaking this down in a way I could understand!!!!
[mention=159655]pgamboa[/mention] I have the 2017 Chevy Tahoe.  Would the module switch with the 2018 GM part work to upgrade/make compatible my charging pad with my iPhone X?  If so can you send me info on your cord where I won’t have to change those pin things and also can you send me the info on where to order the new module.  I did hear in your video that it was on back order...hopefully not now though!  My email is ukpa09 at gmail.com -thanks a bunch!!!! And by the way- I’m in medicine and am not mechanically inclined- thank you for breaking this down in a way I could understand!!!!
Send me this message to [email protected]
I have these ready made and ships in 1-2 days.
Thanks!
My Samsung Galaxy s8 wireless charges in a magpul case. I did have to take the rubber mat out of the charger, rotate it 180 degrees, cut the alignment nub off the rubber mat, and put it back in for it to work. Took about 5 minutes and is a great feature that I use every day. Keeps the console area clean and free of wires which I like.
Note on the fitment of the phone into the pad, it fits completely perfect with no wiggle room side to side and some room to go forward and back. I keep mine in the all the way back position and that works for me. The case is a good one for the phone too as far as drops and grip etc.
Just my $0.02
  • 3 weeks later...
Has anyone got the Pixel XL to wireless charge in the GM wireless charge pads? I have the '17 High Country but it doesn't seem to want to work. It is like a millimeter too wide to sit perfectly flat. I tried searching, but you get 100's of replies because "Sent from my Pixel"....
But curious if anyone is wireless charging with any Pixel XL or similar 3" wide phones and how they got it to work. Really not pumped about trying to shave down the large plastic trim around the rubber mat to make it a hair wider but that seems like the next step...
Edited by grafik
  • 10 months later...
Wanted to provide some information regarding recent phones as of summer 2020.
I just did a PnP retrofit kit from @pgamboa's site and had a great experience with it and the install videos.  As of this post I have not been able to find the updated 2018 model 10 rib charging mat in stock anywhere (if they can even track down the actual 10 rib version at all with the weird part# stuff), but was happy to see my Samsung Galaxy S20 5G+ is able to consistently charge without issue on the 2017 9 rib version mat with the tall backstop already in the truck.
I didn't see any of the install videos reference it specifically, but if you were preoccupied with not breaking the console and didn't notice exactly how the original wiring is ran, there are channels for it inside the console ribbing itself and a cutout to hold the wiring in place along the hinge included on the driver's side hinge area of the underside plastic cover.
I just did a PnP retrofit kit from [mention=159655]pgamboa[/mention]'s site and had a great experience with it and the install videos.  As of this post I have not been able to find the updated 2018 model 10 rib charging mat in stock anywhere (if they can even track down the actual 10 rib version at all with the weird part# stuff), but was happy to see my Samsung Galaxy S20 5G+ is able to consistently charge without issue on the 2017 9 rib version mat with the tall backstop already in the truck.
Thanks for sharing!
Hope this helps.
84199943 - Matt (10-Rib)
23264395 - Matt (9-Rib)
How well are your devices charging?  I installed the charging pad into my '16 Denali and it seems to trickle at best.  If not using the phone (iphone 8 plus) it will very slowly add charge to the battery but if its being used for maps the charge drops but not as quickly as if not connected.  If I run Waze, that's a joke; the charge doesn't even begin to keep up.
Am I just expecting too much?
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
