Less than 1,000 miles brakes started squeaking while applying light pressure before stopping. Thought might have been a burr on the roter or pad, gave it some, still squeaking now enough that if tic me off. Took it to the dealer, gave me a loaner and had it for four days. Finally made a phone call and the adviser said that I must have drove through something that made them squeak. Anyway he said that they are not squeaking any longer either cold or hot. Picked truck up last nite and today squeaking again. Should I take it back or give it some time to see if it fixes itself?
About 9,000 miles on mine. My brakes have squeaked almost since day one. Had them checked at first oil change. Dealer said no problems. Said brakes they use now build up a slight surface rust very quickly when exposed to moisture.
Mine developed a brake squeal a week after I bought it. I'm not worried about it, just annoying to hear it. It seems intermittent whether warm or cold. I assumed it was because of the muddy/gravel and then dry mix I frequently drive on. Some of my trucks have squealed and some haven't. Just interesting to see this thread here. The brakes themselves are performing as good as can be but I think I'll let the dealer know next service just because.
Well it has been wet around lately, but they should not squeak, and you would think that after use the rust would wear off.
Well it has been wet around here, the brakes still should not squeak and you thing that after use the rust would wear off.
sorry about the triple post, dang computers, the brakes are working properly in my mine that was the main reason for taking it in. I agree when I take it in for first oil change or for another need I will mention the squeaking.
Us old guys and technology don't mix.
I did catch a rock the first few days after the muddy gravel. The forward/reverse trick didn't work after several tries so I just drove back on the highway as normal (the faster I went the less I heard the grinding lol) but at some point it shot that little stone out. Maybe that has something to do with it? I don't know.
Mine does it too, only when applying the brakes lightly. Glad I'm not the only one. I was planning to mention it to the dealer when I take it for it's first oil change, but it sounds like I shouldn't get my hopes up...
My 15 25HD has a brake squeak every morning when I 1st apply the brake doing down my driveway --- then all quiet the rest of the day -- currently 52,000 miles
Yea that what mine light application on brakes, once you go for the full stop they quit.
Anyone else starting to get brakes that squeal on their 2017 2500 HD ???
Just started hearing them a bit over 1100 miles now.:(
PS, @GM Customer Service, please check over and clear out some of your private messages as they seem to be at their max limit due to I keep receiving the following message while trying to send you a private message:
The following errors were found
The member GM Customer Service cannot receive any new messages
This personal message has not been sent
Clearing either some or all of them would help allow new messages to come in.....Thanks.:)
Mine squeak first thing backing out of the driveway but then they are OK, and it doesn't happen all the time. You should do a pad slap and use a ceramic pad, they worked for me on my Excursion. You can scuff up the rotor with sandpaper to get the glaze off then just take it easy for the first few stops. This is a cheap and easy "try" that you can do yourself.
I got same issue with squeaking brake in the morning. Goes away quickly.
Mine squeals constantly, not just at startup and does it when it's bone dry mid-day (not wet) after driving for 30 mins+ as well. Sounds like it comes primarily from the passenger side front brake.
I mentioned at my first (1k) oil change and service rep told me it was normal for ceramic pads or something similar and that it would go away - it was a Saturday and the guy had a huge line so I didn't push. It's loud and annoying and have planned to make a couple of videos to take with me at my next service in case they tell me they can't reproduce it.
I'm currently about 3,300 miles.
Edited by dave_clt
I noticed mine squeak only after going down dusty roads. Car wash and all is good after that.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
