Again thanks to@pgamboa for all the help with chasing wires and locating pieces I needed.
  • 3 years later...
@Csjumper2003
I'd be very curious what option truck you're staring with (I have an LT1) and what was in place.
  1. What is the part number of the fuse block you installed?
  2. Were the wires between the driver's fuse block and the plug for the over head console in place?
  3. Were the wires that go from the overhead console plug to the instrument panel in place?
  4. Where the wires that went from the instrument panel to the rh fuse box in place?
  5. Were the wires that went from the rh fuse box to the <motor location> in place?
I can't imagine #5 was present. If not... did you simply have to add those two wires from the fuse block back to the motor location? Pictures would be awesome.
I just swapped out my overhead console for one with HomeLink and it also had the rear window button. A button that does nothing is not sitting well with me. I'm just glad I didn't buy a console with the sunroof buttons, too.
Edited by David W S
6 minutes ago, Anthonyvee90 said:
titan window
A window out of a Nissan Titan?
4 minutes ago, Anthonyvee90 said:
Yes
Interesting, didn't know that a titan window would fit
15 minutes ago, PFTX_5.3 said:
Badass, I spot a mirror camera too
good eye
Mirror-says sold out but if you message him, he’ll sell it to you.Mirror
Camera-Part#84486910
Cable-Cable
3rd brake light Gasket-Gasket
3rd brake light still works
Edited by Anthonyvee90
added pic
7 hours ago, Anthonyvee90 said:
wired to oem switch
I would like more information on the wiring to the oem switch. I am planning on doing this and was going to wire it to the oem switch myself.
Sorry what I meant to say was wired to oem switch location with after market button. Wired to oem switch but wouldn’t work 5 pin usually is
pin1:window motor
pin2:ground
pin3:12v
pin4:ground
pin5:window motor
but couldn’t get it to work if you figure it out let me know please
12 hours ago, Anthonyvee90 said:
good eye
Cable-Cable
I've thought about it but I rarely use that mirror, my first car didn't have one so I got in the habit of only using my side mirrors
pin1:window motor
pin2:ground
pin3:12v
pin4:ground
pin5:window motor
Will do. It might be awhile before I get to that the 2014 is nearing time for a new engine. I'm saving up for a l8t swap.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
