What are these buttons on steering wheel
Got this on eBay to add heated seat to my truck. Does anyone know what these four bottoms on the back of it are for? Have never seen these before.
The right side controls the volume while the left side changes the stations. Assuming you have the base system?
I have a 4.2 WT system that I'm moding the hell out of lol awesome news, didn't know these wheels had that.
I'm just waiting for a Denali cluster to get programmed then going to do the total retrofit.
Might want to check to see if the WT radio is compatible with these switches. Works with the larger nav screen.
Heated seats are controlled on the steering wheel???
Mine on the console area under the HVAC.
There's a heated wheel button on the wheel :thumbs:
I know, I just upgraded to 8" with i05. Next I'll put a Denali cluster in, then the heated steering wheel, then time to hardwire it all in.
Exactly. Hey WesternSilverado -- you didn't need to buy a new steering wheel to get the heated seats. You need the trim piece that goes around the HVAC controls.
Yea the same on my truck ??
So steering wheels with audio controls CAN be added to work truck package? I was thinking it wasn't possible. I LIKE THIS, if it indeed is possible!!!!! :)
i had a thought about a mod on the use of those control buttons.how about making those buttons control the up/down shift of the tranny?i know you would have to splice into the wiring but i think it is very do able.i would rather use those buttons on the steering to shift the tranny.then to use the +/- buttons on the shift lever.
I didn't say i was adding this for heated seats? Lol I'm adding the heated steering to have a heated steering wheel and also controls for denalli cluster.
But I am adding heated seats and swapping to black cloth and even using the oem dash buttons for the heated seats.
This WT is going to be heavily modded, you'll never know it's a WT besides the floor; which I'll never change as I'd never have carpet.
- I'm also adding a rear sliding window.
- Already added home link.
- Already Added Center console
- Dimming top mirror
- the full led Denali cluster
- 8" Upgrade with io5 already done
- adding back up cam
And the list will keep going. Just follow me for posts about it all. Will post some videos of the mods when I have time.
