1 hour ago, Waterfowler41 said:
How did you reinstall the new hooks without removing the bumper?
I cut my bolts for a bull bar and want to reinstall my tow hooks but see no other way other than removing the bumper.
Just pushed the new hooks back in.  There is a plastic piece with a notch in it and a piece of foam.  Didn't have to remove bumper at all.
2 hours ago, ChevyRoofer said:
Anyway you can tell me the stats on the bolt head to install the hooks?  I'd like to pick up two from HD (my truck is a 2WD) since I'm buying my recovery hooks on CL.
18mm hex head bolt.  You should get 2 per hook if bought new.
I was wondering more about the bolts, the long bolt that goes through the tow hooks, ( the one you had to cut to remove the hooks) how’d you get that bad boy reinstalled?
Just turn it around  and come in the other way.   I believe from the factory the bolt head is facing inboard.  Just turn the bolt and come in from the outboard side and put the nut on the inboard side.
...I can’t believe I didn’t consider that....
Thanks Man!
Thanks Man!
No problem
Do you happen to know what the thread pitch is?  18x1.5?
@ChevyRoofer and @Waterfowler41
I'll be sending you your refund tonight WaterFowler so that you don't have to spend money on me shipping them to you unless you'd still like that. That is up to you.
The bolts you're looking for are class 10.9 bolts.
M12x1.75.
2x 110mm bolts
2x 50mm bolts
2x m12x1.75 nuts.
You can find the bolts here.
https://www.mcmaster.com/#standard-hex-head-screws/=1a6s92v
Either a 45 or 50 will work. Hell a 40mm will work as well. The 100 should work as well instead of a 110mm.
Trying to thread the nut however seems like its some sort of locknut. It doesn't have any insert though but I would suggest you get a locknut and a washer or just the flanged nut and some threadlocker.
Locknut here
https://www.mcmaster.com/#hex-locknuts/=1a6sa3x
The flanged locknuts are available here.
https://www.mcmaster.com/#hex-locknuts/=1a6sar4
All of these look like they want you to buy quite a few to get the couple you need.
Of course you can always source these from your local hardware store although I couldn't find any class 10 flanged locknuts at my Lowes.
Edited by snowbrdd
  • 5 months later...
On ‎11‎/‎8‎/‎2017 at 3:47 PM, snowbrdd said:
I'm sorry, but at 500 bucks for a set of tow hooks, that is insane. You can get the red ones from GM for 100 bucks or the black for 50. That price is way too rich for my blood.
Just now saw the GM chrome hooks for $120 on ebay...
  • 9 months later...
15 minutes ago, Red Autumn said:
I have a 18 Silverado 1500 and cannot find the actual chevy tow hook or specific instructions to install one. It does not have the cut outs yet
Welcome to the site. Can you post a picture of the front of your truck? Did not realize there was model without tow hooks on it from the factory.
  • 2 years later...
Old thread but thought it was fitting here. Rough country released a tow hook to d ring option for around $70 (doesn’t include tow hooks). They sell them on Amazon as well. Glad you guys were here to help me feel less crazy about my 16’ not having the 3 bolts from the video
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 719 Guests (See full list)
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
