How exactly does climate control work on the 2014 silverado? A/C issue
ok so to start my a/c went out not to long ago in my 2014 LT ..it was the condenser I got it replaced with aftermarket...coming home from that I noticed my truck shifting really weird then it stopped! The condenser line blew out causing tranny fluid to go all over the place...filled it u went on my way long story short brought it to my local dealer and needed to rebuild my whole transmission (thank god I still have drive train) so now I have noticed that sometimes my a/c will blow colder than other times...ill be driving home from work (10 mile drive) and i notice it will be blowing hard than will blow soft out of nowhere. if im at the store and leave the truck running it will be blowing then blow hard when i hit the gas and soft again when I let off. when using on star it will blow soft until i hang up then blow hard again...I also feel that it isnt blowing as cool as it should... if im at 60 degrees it feels like it should be alot colder and when i turn it down once to low it gets cold...I just dont know if the blower should be doing that because of climate control or what or if anyone can address these issues...thanks
There's a feature that turns the blower down when you're on the phone or on with onstar. It's to make it easier for the other party to hear you. This happens whether you have auto on or not.
Any other stuff, I'm not sure about. It shouldn't be affected by your foot on the gas, but it could be the sensor on the dash detecting the sun and adjusting the AC.
I know my SLT and previous LTZ , both equipped with climate control, would adjust the fan based on the difference between measured cab temperature and the target temperature. If you wind the target temperature down on both sides (L & R) to well below the actual cab temp, it will run the fan at the highest speed, until it gets close to the target temp. If the outside temp is near the target temp, the blend doors will allow a mix.
If you have dual climate control it will do that if it is set to "auto". I don't recall mine adjusting the fan speed if it isn't set to auto except when I'm making a call.
agreed
Are sure the fan is actually changing speed? The recirculation door will open and close at times and the noise from the fan will change substantially.
Automatic Operation
The system automatically controls
the fan speed, air delivery, air
conditioning, and recirculation in
order to heat or cool the vehicle to
the desired temperature.
When the indicator light is on, the
system is in full automatic operation.
If the air delivery mode or fan
setting is manually adjusted, the
auto indicator turns off and displays
will show the selected settings.
To place the system in
automatic mode:
1. Press AUTO.
2. Set the driver and passenger
temperature.
To find your comfort setting,
start with 22 °C (72 °F) and
allow the system time to
stabilize. Then adjust the
temperature as needed for best
comfort.
To improve fuel efficiency and to
cool the vehicle faster, recirculation
may be automatically selected in
warm weather.
The recirculation light will not come
on when automatically controlled.
Press@to manually select
recirculation; press it again to select
outside air.
Do not cover the solar sensor on the
top of the instrument panel near the
windshield. This sensor regulates
air temperature based on sun load.
See “Sensors” later in this section.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 799 Guests (See full list)
