I prefer painted. The color doesn't match the chrome.
Can i remove the chrome trim while installed on the truck? going off of memory, it's just a few tabs right?
For the handle part, you have to remove the screw at the end, and then have to slide it off, towards the rear(if it's on the truck already), not sure if the part that bends around the end will clear the smaller part. Also, the small part(other part of the handle), you have to release the tabs from inside...
Sure, no problem, but the install might not happen anytime soon. Weekends are getting busy and so is work. I just wanted to have the parts ready just in case I get an unexpected free weekend.. [emoji1]
Sent from my XT1575 using Tapatalk
No problem as I am not in a hurry to spend more money either! LOL
I didn't even know this was a thing . . . :dunno:
Oh no :banghead:
Neither did I, but my hats off to people like Phil who like to tinker and think of these things!
Thanks! I saw someone posted about these handles here and actually did. So while I was certainly not the first, I wanted to share and document my experience so that others could can also achieve this upgrade.
Wanted to share some pics on the driver side door “Keyhole Delete” when retrofitting these handles.
Thanks to @cbrsilv15 for the tip!
I left my cylinder in the base as I didn’t want to mess with the removing it. So when you remove the base, the cylinder stays in.
The worry I had was in the event of a dead battery, how I could get into the truck. Well, thanks to @cbrsilv15, he shared the process.
Pull the handle, and push the cover off to reveal the key hole. It was that easy!
https://uploads.tapatalk-cdn.com/20170924/4d37f09468d2308c95ae8809b836765f.heic
https://uploads.tapatalk-cdn.com/20170924/bcf252cb222a2637707ac76c0101cd44.heic
  • Like 7
Was it really that easy to pull off? From you video I thought you had to push up on some tabs from underneath.
Now I feel like gave bndawgs wrong info on removing the chrome trim pieces once it's already in place.. :banghead:
Just finished adding Escalade - Illuminated Door Handles. Made a "How-To" video for it. Took me about 6 hours but mainly due to recording the video.
Look the new look!
Looks great can't wait to do this. Thanks for sharing.
There are tabs underneath but when cbsilv15 shared a YouTube video of a dealer showing how to access in the case of a dead battery, I tried it and it worked.
I was wondering about that if the battery died. That's comforting to know. Now I need to decide whether to stay with chrome or try and get the tops painted.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,075 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
