Until the engine is on the verge of overheating.
Started after a few times taking the positive battery cable off and on. Now no high speed with ac or normal operation. Bmc error and air bag codes. Went to a local shop and they were able to ramp it up with a computer. They suggested bad grounds. Cleaned them still the issue persist.
At the point I want to run a relay and battery voltage to the fans.
Anyone know what wire on the fans gets full voltage?
if the brakes are good and you keep an eye on them, just disable the stupid thing and call it a day. You can pick each set and disable it in the menu on the dash just to see if it stops the annoying nagging prompt.
